Hilux 2.4Diesel Engine
Submitted: Saturday, Aug 21, 2004 at 18:36
ThreadID: 15725 Views:3788 Replies:4 FollowUps:4
Can anyone tell me what the factory rated horsepower of a Hilux 2.4 Diesel engine is? I wish to use one of these engines for a different application and require this spec.
Reply By: Member - Jiarna (SA) - Saturday, Aug 21, 2004 at 19:39
61 kW or 82HP
AnswerID: 73519
Follow Up By: markp - Tuesday, Aug 31, 2004 at 23:21
Hi Jiarna,
Been a while following up as I've been away. First trip away in my Hilux WITHOUT the 2.4D - have 253'd it and drives beautifully!
Anyway, the 2.4D I am wishing to set up on an irrigation spray pump. I need to size the pump correctly so hence the need to have an accurate power rating on the engine. It's in VG cond having been rebuilt not long ago, so it would be close the factory rating. Can you tell me where to find a factory rating for one? The 61kW rating you gave me does sound a bit high. Failing that do you know anyone who has had a stock 2.4D on a dyno?
FollowupID: 334612
Follow Up By: Member - Jiarna (SA) - Thursday, Sep 02, 2004 at 13:17
Best bet would be to check the specs in a workshop manual - sorry can't help with that!
Good luck
FollowupID: 334734
Reply By: ianmc - Saturday, Aug 21, 2004 at 22:22
I think you are a bit optimist Jiarna @ 61kw. Isnt that the rating of the 2.8d
AnswerID: 73528
Follow Up By: Member - Jiarna (SA) - Saturday, Aug 21, 2004 at 22:45
Might be right, although I have the 2.8 rated at 68kW. Still struggles to pull the skin off a bowl of custard.
FollowupID: 333664
Reply By: V8Diesel - Sunday, Aug 22, 2004 at 16:26
Driving one indicated about 3 snail power from memory. ;)
AnswerID: 73582
Reply By: Paul from Denco Diesel and Turbo - Friday, Sep 03, 2004 at 15:40
Between 48 - 58 depending on the vehicle.
AnswerID: 75031
Follow Up By: markp - Monday, Sep 06, 2004 at 11:28
Thanks Paul.
I assume that is kW??
FollowupID: 335083
