Excessive play in steering
Submitted: Monday, Aug 23, 2004 at 13:09
ThreadID: 15762 Views:1868 Replies:2 FollowUps:2
Hi All
Have a quick question relating to my hilux - rigid front end.
I have adjusted the plug on the draglink but there is still too much play. Do i need to replace the draglink and the pitman arm or is there another alternative.
Thanks for the help.
Troy
Reply By: thomo - Monday, Aug 23, 2004 at 19:05
Have you adjusted the steering box aswell.
AnswerID: 73709
Follow Up By: troy - Tuesday, Aug 24, 2004 at 19:50
Thanks for the input
FollowupID: 333915
Reply By: Member - JEFF - Tuesday, Aug 24, 2004 at 06:34
G'day troy
Thomo's right have your steering box adjusted My ridgid axle 4 Runner (same as hilux) 1985 had the same problem, you know, sloppy steering ,has a tendancy to wonder around at speed, adjusted the box and it improved by 70% that's if you have enough adjustment left ??
SEEYA jeff
AnswerID: 73746
thanks champ
FollowupID: 333916
