Prado brake pedal
Submitted: Wednesday, Aug 25, 2004 at 19:53
ThreadID: 15817 Views:3146 Replies:4 FollowUps:0
My 2000 prado is suffereing probably 5 or 6 cms oF brake pedaL travel before they bite.
I get a hissing sound from the pedal area while the travel occurs. Once they bite they are fine but a drive in a friends prado shows his does not have same problem.
Pads are fine, probaly 70% front and similar rear.
I have just had the brake fluid replaced and bled.
The car has only done 70,000 ks.
Reply By: Moz - Wednesday, Aug 25, 2004 at 20:34
Teejae,
Could be a brake booster problem.
Does the pedal feel soft, spongy or hard?
Is the pedal travelling further than it used to before the brakes bite?
Moz
AnswerID: 73945
Reply By: Savvas - Thursday, Aug 26, 2004 at 08:05
The hissing sound would indicate a brake booster/master cylinder problem.
Is it intermittent or is it every time you use the brakes?
AnswerID: 74010
Reply By: Member - Jeff M (WA) - Thursday, Aug 26, 2004 at 12:59
Could be the vacum pump or a leak in the pressure system.
AnswerID: 74058
Reply By: Phil G - Friday, Aug 27, 2004 at 21:34
I think they must have let some air in and not bled it out. I'm guessing a rebleed may fix it.
I'm assuming you don't have ABS, as this is a different ballgame.
AnswerID: 74306
