Holden Jackaroo
Submitted: Thursday, Aug 26, 2004 at 09:23
Member - ramp
Hi a friend of
mine has a petrol jackaroo 3.5 litre 2001 auto model and has a problem with the engine pinging if he uses less than 98 octane fuel, Has anyone out their had the same problem and found out how to fix it.
Reply By: VWR - Thursday, Aug 26, 2004 at 10:36
Wecome to the land of the Jack - There are many things you can try including injector cleans off vehicle but really there is only one solution and you have found it PULP.
I have the same vehicle 2000 model and it drove me mad too - PULP will give you better performance and possibly better L per 100K so that offsets the cost a little. 95 octane from BP should be O'K and in NSW that is only 5c dearer, I don't know where you are but I guess the differential would be similar.
Caltex is only 6c dearer
If a refill is 50L that is $3
If you improve L per 100K by 1 that is 3-4 litres less per fill at >$1 per L
74034
Follow Up By: VWR - Thursday, Aug 26, 2004 at 10:37
P.S. Forget **^%#$%% Holden Dealers, they don't know know what they are talking about with these things (Isuzu's)
334046
Reply By: Banjo - Thursday, Aug 26, 2004 at 11:58
It is true that the some GMH dealers know bugger all about Jacks - my main issue with
mine was that they didn't seem to give a hoot about customer relations and fair dealing - what they did give a hoot about was dishonesty - that they were good at.
74042
Reply By: Savvas - Thursday, Aug 26, 2004 at 19:06
95 PULP should be enough to do the trick. If not, then an off car injector clean is needed.
Mine had an off car injector clean at 60000kms (or thereabouts) and a bottle of Nulon Injector Cleaner goes in every 5000kms now too. I now run ULP without pinging and it is upto 83000kms.
74116
Reply By: Member - Bradley- Monday, Aug 30, 2004 at 13:41
I found that they suffer as soon as the fuel filter gets blocked up a bit, i change
mine every service. Ex bosses jack had the ping the dealer couldn't fix , took me ten minutes to sling in a new filter and the prob was solved straight away.
Just my experience.
ps - i normally run optimax but it has no dramas running on regular unleaded either. Also don't be shy of blowing out the cobwebs on a regular basis....
74511
