What rig to choose??
Submitted: Thursday, Aug 26, 2004 at 21:35
ThreadID: 15857 Views:2495 Replies:7 FollowUps:7
Im in the market for a new rig and i am tossing up between a 4.2 GXL Landcruiser or something smaller like the GLS 3.5 Pajero or a Jackeroo turbo diesel.
Any Ideas????
Reply By: Truckster (Vic) - Thursday, Aug 26, 2004 at 21:40
What do you want it for?
Why not go drive them all, that will usually answer your own questions.
They dont make Jackaroos anymore I thought?
YMMV
AnswerID: 74150
Reply By: Bob H - Thursday, Aug 26, 2004 at 21:44
your decision but remember to take into account wheather you are going to be towing and what size/weight and what distances. I own an 80 series 4.2 natural and tow 1.9tn van with no trouble except on hills of course. Personally, Id go the toyota, either l/c or prado.
AnswerID: 74151
Reply By: Crackles - Thursday, Aug 26, 2004 at 21:47
No point getting a whopping big cruiser if you don't need the space. The Turbo diesel Prado would be (IMHO) the pick of the mid sized 4by's at the moment.
Take one for a drive & see if it fits your bill.
Craig
HZ105 croozer
AnswerID: 74152
Follow Up By: Member - Jeff M (WA) - Friday, Aug 27, 2004 at 13:05
I'll second that.
FollowupID: 334197
Follow Up By: Joe - Sunday, Aug 29, 2004 at 21:28
We run a tape over my mates 80series and my 120 to compare recently. Surprised to find that the Prado 120 was tad wider and longer.
Mid size???
Joe
FollowupID: 334367
Reply By: Member - Bob - Thursday, Aug 26, 2004 at 22:05
If cost matters then you go through the process of deciding Petrol/Diesel, Big/Medium, Handling/Off road ability. Then personal preference between brands. If cost doesn't matter go out and buy a L/C turbo diesel anyway.
Both the (available) vehicles you mention are excellent products but vastly different in their strengths and weaknesses, and the engineering solutions they adopt. I'd personally have a diesel before a petrol anyday, so would opt for the auto diesel pajero ahead of the 3.5 petrol. Both are vastly more economical than the petrol Toyotas (either V8 or six). The Paj doesn't have the rail chassis of the Toyo - it's monocoque, so lighter and a lower centre of gravity. The Toyo is quite a bit bigger so will carry more. It doesn't handle as well on the road, but is generally regarded as more capable off road.
AnswerID: 74159
Reply By: MrBitchi - Friday, Aug 27, 2004 at 08:46
Take a test drive in a DID Pajero. Best of the bunch IMHO. Will tow as well if not beter than a LC.
Back to back test drive with a Prado will leave you wondering why Toyotas are so expensive........
Yes I'm biased............
AnswerID: 74199
Follow Up By: Member - Jeff M (WA) - Friday, Aug 27, 2004 at 13:26
Until you get air out in the dunes and you find your roof is no longer straight but has an odd curve upwards! LOL
Just stiring, I'm sure the Paj is a good truck.
But IMHO I would not by a 4by without a rigid chasis.
FollowupID: 334200
Reply By: MrBitchi - Friday, Aug 27, 2004 at 13:59
This is sure to start a war.....
From the relevant web sites:-
Pajero DID
Maximum power 121kW @ 3800rpm
Maximum torque 373Nm @ 2000rpm
Kerb mass (kg) 2180
Ground clearance (mm) 225
18 KG/KW
RRP $56990
Prado
Maximum Power 96kW @ 3600rpm
Maximum Torque 343Nm @ 2000rpm
Kerb Weight (kg) 2170
Ground clearance (mm) 207
22.6 KG/KW
RRP $52660
LC100 GXL
Maximum Power 96kW @ 3800rpm
Maximum Torque 285Nm @ 2200rpm
Kerb Weight (kg) 2325-2370kg
Ground clearance (mm) 210
24.6 KG/KW
RRP $61990
LC100 GXL Turbo
Maximum Power 150kW @ 3400rpm
Maximum Torque 430Nm @ 1400rpm
Kerb Weight (kg) 2510-2550kg
17 KG/KW
RRP $70990
No brainer. The turbo cruiser is a more powerful beast and marginally better power to weight than the Pajero.
Unless your going to be doing a lot of heavy towing (or you win Lotto) you can't beat the Pajero.
IMHO
AnswerID: 74253
Follow Up By: Wombat - Friday, Aug 27, 2004 at 15:51
Holden Astra 1.8 litre
Maximum Power 90kW @ 5600rpm
Maximum Torque 92Nm @ 5600rpm
Ground clearance - Not relevant to your argument
Kerb Weight (kg) 1164/1184
13 KG/KW
RRP $19990
No brainer? According to your argument John power to weight ratio is the only consideration when purchasing a vehicle. On this basis we had better all go out and buy a good ols 4.0litre Chrysler Centura. And they're cheap too!!!!
FollowupID: 334211
Follow Up By: MrBitchi - Friday, Aug 27, 2004 at 18:15
Wombat,
Just trying to point out value for money. The Pajero is more powerful and has better ground clearance than the Toyota's. Ok, the turbo LC is more powerful, but more expensive, the Prado is slightly cheaper but less powerful. Better power to weight equates to better fuel economy and better performance. All round the Pajero is far better value for money.
IMHO (and like I said, yes I am biased, I own a Pajero)
Have a good weekend.
FollowupID: 334227
Follow Up By: Alex Callaghan - Saturday, Aug 28, 2004 at 18:31
Mrbitchi,
Almost sounds like your trying to justifie your purchase to yourself!
FollowupID: 334283
Follow Up By: MrBitchi - Sunday, Aug 29, 2004 at 10:45
Actually, Alex, when I went shopping for this car the number one vehicle on my list was the Landcruiser, but when I did the comparison I couldn't justify the extra dollars for the LC over the Pajero. 12 months down the track I'm even more convinced.
FollowupID: 334322
Reply By: wombat1 - Sunday, Sep 05, 2004 at 19:43
This may seem left of centre but have you considered landrover Discovery. Have taken delivery in last few months and have to say it has exceeded my expectations in both performance and build quality. Tows my 17'6" tandem with ease, excellent vision and great off road. Every vehicle has its compromises but this package is good. Diesel Auto and some pretty good run ou deals on
AnswerID: 75241
