Bridgestone Duellert 693 Recall
Submitted: Tuesday, Aug 31, 2004 at 11:15
Outnabout David (SA)
Just reading the paper today and saw this recall notice.
Recall Dueller AT 693
Reply By: Vince NSW - Tuesday, Aug 31, 2004 at 11:45
What a strange recall notice !!!
When you read it, it is not clear if they have been recalled or not
Vince
74645
Reply By: Truckster (Vic) - Tuesday, Aug 31, 2004 at 16:36
I get
Error
An error has occurred that prevents your request from being processed.
The most likely cause of this error is that you have come to www.recalls.gov.au The Product Recalls Australia web site from another web site, and have not arrived at the home page.
Please enter through the Product Recalls Australia home page.
If you are trying to reach the home page but are still receiving this error we apologise. Detailed error information has been sent to our Web development team, who will get right onto it.
74690
Reply By: dogart - Tuesday, Aug 31, 2004 at 18:36
ere ya go Truckster...
Bridgestone Motor Vehicle Tyre, Dueler A/T 693 pattern
Date: 31/08/2004
Supplier: Bridgestone Australia Ltd
Category: Motor Vehicle Accessories
Product Info: Bridgestone Motor Vehicle Tyre, Dueler A/T 693 pattern and has the Bridgestone brand on its sidewall. The product has a DOT serial code with the prefix EJ LF CCB. Tyres in size LT285/75R16 122/119Q. Production Date: 1 July 1998 - 31 July 2002 by Bridgestone. Manufactured in Japan. The tyre is principally fitted to larger four wheel drive vehicles.
Defect details: It is possible that a small percentage of the tyres may experience belt detachment, especially if operated below recommended inflation pressures for the load carried by the tyre or above the maximum load. If inflated to the correct pressure and not overloaded, the tyres will perform
Consumer action: Consumers should check their tyres to identify the Product and obtain assistance by calling toll free 1800 354 864 to arrange an inspection.
Market Coverage: National
Recall Coverage: National
74710
Reply By: Bitsumishin - Mike (WA) - Tuesday, Aug 31, 2004 at 19:56
Jeez. Designed for larger 4 wheel drives but "It is possible that a small percentage of the tyres may experience belt detachment, especially if operated below recommended inflation pressures".
I thought the whole idea of a 4x4 was to play around in areas where lowering tyre pressures was a necessity. It sounds like they are saying as long as you don't lower pressures, you should be OK. Glad my 693s are 15"
74730
