CAV filter with primer
Submitted: Thursday, Sep 02, 2004 at 19:42
ThreadID: 15989 Views:3278 Replies:5 FollowUps:3
Going to change the twin CAV filter setup(useing filter in one and the other as water trap only)to a single setup.BUT I need a primer in the system as out woop woop its a bit harder to fill the filters up to bleed system.The original filter/primer is U/S.Can you get a CAV type filter ass. with a inbuilt primer?
Cheers all Nick
Reply By: hoyks - Thursday, Sep 02, 2004 at 20:26
Yes you can. From memory they are about $110. there are som pictures of the one I have here:
hoyks's filter
AnswerID: 74926
Follow Up By: Member - Nick (TAS) - Thursday, Sep 02, 2004 at 20:37
Thanks hoyks,any idea who sells them?Ive tried heaps of places and most reacon you carnt get em.
FollowupID: 334768
Follow Up By: hoyks - Friday, Sep 03, 2004 at 16:01
I got mine from Mayfield Diesel Service. So any self respecting diesel injector place should be able to get you one.
Australian agents for Delphi
Delphi used to be Lucas, so they are the same thing.
FollowupID: 334864
http://www.delphidieselsystems.com/dieselglobal/eng/agentsearch.asp
FollowupID: 334865
Reply By: Peter 2 - Thursday, Sep 02, 2004 at 21:02
Any decent diesel shop should be able to help you.
AnswerID: 74933
Reply By: Member - Roachie (SA) - Thursday, Sep 02, 2004 at 22:42
What about trying the wreckers......it might be a different vehicle brand/model, but could work. EG: a Nissan Patrol primer could be bolted on and use an adapter for the CAV .....Denso (or Denco??) make them.
AnswerID: 74949
Reply By: Paul from Denco Diesel and Turbo - Friday, Sep 03, 2004 at 14:43
Denco Diesel sell these filter assemblies with primers and will throw in a spare replacement filter free of charge. The filter assemblies are $109.00 plus any fittings that you may need.
AnswerID: 75024
Reply By: Member - Nick (TAS) - Friday, Sep 03, 2004 at 21:53
Thanks all,I'll see what I can turn up.
AnswerID: 75077
