Hilux extra cab seats
Submitted: Sunday, Sep 05, 2004 at 20:21
buzz box
Im trying to figure out how to remove the folding rear
seat in my extra cab Hilux (95 model). I'm looking to put a 40L Engel behind the pax
seat on the shelf. It'll be a tight fit, so I dont want to sit it on the cushion.
I got the plastic cover off, unbolted and removed the spring, then got stumped. Do you need to remove the trim and unbolt the hinge on the back section? If so, how does the trim come off?
Thanks in advance!
Reply By: Wisey (NSW) - Monday, Sep 06, 2004 at 17:10
Hi Buzz Box,
remove plastic panel above backrest via 2 little access holes, backrest is clipped in by memory, unbolt hinges and remove
seat bases.
Make a board to fit, fix it down using one of the
seat belt base mounts, cut board around
seat belt fitting in corner, 15mm strip along front underside to level up board. Fixings to hold fridge in place and load it in.......
Access and height are the only probs from there....
awise181atbigponddotcom for a picture/sizes of the board
75349
