80 series oil pressure guage problem
Submitted: Tuesday, Sep 07, 2004 at 14:38
ThreadID: 16098 Views:6877 Replies:5 FollowUps:6
Oil pressure quage not working on my 80 series TD 1991 model. I earthed out the lead and the guage read full - so i changed the sender unit...still not working. Is this a common problem? any suggestions to fix?
Help appreciated, twigiee
Reply By: Truckster (Vic) - Tuesday, Sep 07, 2004 at 15:34
have a look at www.lcool.org, and Technical page
AnswerID: 75516
Reply By: Utemad - Tuesday, Sep 07, 2004 at 15:54
Put some oil in it LOL
AnswerID: 75519
Follow Up By: Twigiee - Tuesday, Sep 07, 2004 at 16:06
And perhaps start the engine...ha ha
FollowupID: 335307
Reply By: Kiwi Ray - Tuesday, Sep 07, 2004 at 15:56
Hi Twigiee
I would suggest that you put a manual test gauge in to get a true reading and work from there.
Ray
AnswerID: 75520
Reply By: Steve - Tuesday, Sep 07, 2004 at 18:15
hI twiggie.
what does you gauge norm show, just rec mine is up over 3/4 always above 1/2.
80 series petrol.?
ta steve
AnswerID: 75545
Follow Up By: Twigiee - Tuesday, Sep 07, 2004 at 22:07
Steve
I only recently bought the car, the guage has not worked since i bought it - so i'm not sure.
FollowupID: 335356
Reply By: Member - DOZER- Tuesday, Sep 07, 2004 at 19:20
One of the recalls on this model was the oil gauge and sender...they read low if not at all...fix is to not look at it. Toyota had to replace sender and gauge as one.
AnswerID: 75558
Follow Up By: Twigiee - Tuesday, Sep 07, 2004 at 22:09
Thanks andrew
sounds like that could be the problem - but as for not looking at it, i'd like some prior warning of potentially fatal engine damage! Think i may get an aftermarket gauge.
Twigiee
FollowupID: 335357
Follow Up By: Member - DOZER- Wednesday, Sep 08, 2004 at 06:03
If you want, i have a spare gauge from an old dash you are welcome to try with your new sender.
If you go aftermarket, make sure you put it where you can see it whilst driving, or look for one of the buzzer type low water/oil, etc alarms.
FollowupID: 335370
Follow Up By: Twigiee - Wednesday, Sep 08, 2004 at 13:17
Thanks for your offer Andrew,
However, your info about 'reading low if not at all' has got me thinking...
( hope your electrically minded!) I'm going to measure the resistance range which both the sender unit and guage (using a pot) operate. If the guage is actually reading low, then installing a resistor (of correct value) in parallel across the sender unit and earth should re-calibrate the gauge such that it operates within the correct range. I will also check that the current running oil pressure is ok (with a temporary gauge).
I reckon this is easier said than done - I'll let you know what happens. Failing that, i may take you up on the gauge offer.
Twigiee
FollowupID: 335435
Follow Up By: Twigiee - Thursday, Oct 07, 2004 at 18:06
I've since checked the resistances of both the gauge and sender unit. The gauge was responding to around 26 - 30 ohms, whereas the sender unit was producing only a 35ohm resistance. I played around with various resistors of around between 50 and 200 ohms in parallel with the sender unit and settled on a 82 ohm 5 watt resistor, which makes the gauge read about right. I hope i've actually got the correct oil pressure - i haven't checked it yet.
Twigiee
FollowupID: 338684
