35 Inch tires on rear door of Patrol
Submitted: Tuesday, Sep 14, 2004 at 21:51
ThreadID: 16281 Views:4438 Replies:5 FollowUps:6
Hello, i am in the process off getting my patrol GU ready for the works but i just thought the 35 inch spare wont fit on the rear wheel bracket, are there replacment brackets that will hold 35's.
Also will the extra weight of the 35 inch tyre affect the rear door on the patrol?
Thank you.
Reply By: Leroy - Tuesday, Sep 14, 2004 at 21:53
Kaymar have a wheel spacer that bolts in the same place that will allow you to mount a 35" tyre. I paid about $85 for mine.
Leroy
AnswerID: 76401
Reply By: Andrew - Tuesday, Sep 14, 2004 at 22:14
Have a read of this thread:
http://forum.patrol4wd.org/phpBB2/viewtopic.php?t=301
AnswerID: 76405
Reply By: Member Eric - Tuesday, Sep 14, 2004 at 22:53
said who that you cant make it fit ?
AnswerID: 76413
Follow Up By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 08:56
Look out, Yoda from Star Wars has logged on as Eric...
"Already know you that which you need...'
FollowupID: 336228
Follow Up By: Member Eric - Wednesday, Sep 15, 2004 at 19:49
???please explain
FollowupID: 336330
Follow Up By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 21:33
Slowly read what you said.
"said who that you cant make it fit ?"
shouldnt it be
"WHO SAID that you cant make it fit?"...
yoda always got it ass backwards on starwars!
FollowupID: 336342
Reply By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 08:57
Lots of people just run them with flat, then inflate when needed.
More weight will always affect the hinge life on any car..
AnswerID: 76447
Follow Up By: Well 55 - Wednesday, Sep 15, 2004 at 09:02
Is that why they run them flat?
FollowupID: 336230
Follow Up By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 10:31
yes, the tire itself is narrower with no air in it. most people have compressors these days so its no issue.
FollowupID: 336251
Follow Up By: Leroy - Wednesday, Sep 15, 2004 at 14:05
I thought you let the tire down cause the 'air' is too heavy!
Leroy
FollowupID: 336270
Reply By: tolch - Wednesday, Sep 15, 2004 at 14:28
The rear door wheel mounting bracket can be raised by about 50mm. There are additional mount holes located on the bracket for this very need.
AnswerID: 76481
