Centre dash plate removal on GU
Submitted: Wednesday, Sep 15, 2004 at 14:08
Austravel
Anyone know how to remove the black vertical plastic cover dash that houses the radio, air con controls etc, etc. I want to fit a DIN mounted UHF to the space under the radio/cassette in a DX GU patrol so need to remove the front surround/cover just in front of the gear shift. Can't see any screws etc so does it just unclip or .........
Reply By: The Crow - Wednesday, Sep 15, 2004 at 14:21
I have a GU ST and It unclips at the botom of the cover below the air cond controls between the dash and black plate their are two groves on on each side that you can stick a blade screw driver in to leaver the plate out just be sure that you wrap something around the screwdriver so you don't mark the dash. If you use a torch you can see the little spots for the screwdriver clearly. Hope this is of some help
| 200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The CrowLifetime Member My Profile My Blog Send Message |
76480
Follow Up By: Austravel - Wednesday, Sep 15, 2004 at 14:52
Thanks, will give it a go on the weekend.
336273
Reply By: Member - Michael (NSW) - Wednesday, Sep 15, 2004 at 14:31
Hi Ya, The crow is correct but just take it easy after you have unclipped it, i think from memory , you can still break clips on the side or the top if you remove to quick. Let us know it the din mount mounts without any gap between the radio and the black cover... Michael
76482
Follow Up By: Austravel - Wednesday, Sep 15, 2004 at 14:53
Thanks, I'll let you know if it all fits in, take some pics if you want.
336274
Reply By: Member - Chris M (QLD) - Wednesday, Sep 15, 2004 at 14:31
Gday mate,
Just be reallllllly careful with the screwdriver, the guys that did the fitting to my gu went a bit crazy ie. did the mumba whilst trying to get the dash plate off and scratched the painted bits. GRRRRRrrr.
Chris.
76483
Know what you mean, one of the reasons I'm doing this one myself.
336275
Follow Up By: Member - Chris M (QLD) - Wednesday, Sep 15, 2004 at 14:54
Good on ya mate, hope it works out!
chris.
336276
Follow Up By: Member - Michael (NSW) - Wednesday, Sep 15, 2004 at 14:59
If you scratch it yourself, you can only blame yourself and you will get over it sooner LOL
336278
Follow Up By: Member - Chris M (QLD) - Wednesday, Sep 15, 2004 at 15:04
That's right and then you can only put a post on this site telling everyone how dodgy YOU are as opposed to a fitter ;-)
336280
Reply By: theratt - Wednesday, Sep 15, 2004 at 17:10
mine also has two screws which sit above the aircon controls
76502
Follow Up By: Austravel - Wednesday, Sep 15, 2004 at 17:12
Thanks, will check tonight.
336296
