CDMA phone with External antenna
Submitted: Wednesday, Sep 15, 2004 at 20:16
ThreadID: 16297 Views:3925 Replies:9 FollowUps:11
Can anyone give me some up to date info on what current CDMA phones are compatible with external antennas? I have been to several stores, and called a few Telstra shops, and no one can tell me if their CDMA phones can take a patch lead for an external antenna.
They are all "pretty sure it can" But I don't want to buy one and then find out I can't get one for it. I was also told the only way I can get a phone connected to an external antenna is to buy an in car kit as well, which I don't really want.
Any info would be greatly appreciated
Reply By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 21:06
Any reason you dont want a carkit?
Lots of advantages..
Dont get done talkin
power over std
better reception etc..
AnswerID: 76524
Follow Up By: Gajm (VIC) - Thursday, Sep 16, 2004 at 07:45
We are leaving for the Corner on the weekend, and I didnt want to fork out for the extra, as I want to get an HF or Sat phone eventualy, the CDMA is just for a few more options
FollowupID: 336370
Follow Up By: Truckster (Vic) - Thursday, Sep 16, 2004 at 11:00
I see what ya sayin, HF is lots o $..
but with teh CDMA, IMWO, you would get better out of it with incar kit.. Got oen for my Kyocera 3245.. wasnt that much, there was even a few on Ebay for $99.00
FollowupID: 336404
Reply By: Allan Mac (VIC) - Wednesday, Sep 15, 2004 at 21:26
without getting into the pros and cons of an external antenna. You dont need a car kit as well. I run a patch lead to the phone direct (Kyocera & Nokia) and it works a treat.
AnswerID: 76531
Follow Up By: Gajm (VIC) - Thursday, Sep 16, 2004 at 07:49
That's the type of set up I was after. What models are the Kyocera & Nokia?
FollowupID: 336374
Follow Up By: Allan Mac (VIC) - Thursday, Sep 16, 2004 at 09:34
I use a Kyocera 2235 and the navigator has a Nokia 6385. there are later models out now but I would imagine the setup to be the same. If you have doubts go to www.steve.com.au or give Steve a ring. There isnt much he doesnt know about mobiles. He is at Leongattha . Just checked he can be contacted on 1300136535
FollowupID: 336394
Follow Up By: Member - Jeff M (WA) - Thursday, Sep 16, 2004 at 14:05
I was told by several stores that the nokia was not able to take an external arial at all??
FollowupID: 336416
Reply By: cj - Wednesday, Sep 15, 2004 at 22:07
Had a patch lead for my old LG but have a new Nokia 3105 and the guy in my Telstra shop sold me a Nokia cradle that has the lead attached for connecting to an external antenna and also allows me to plug in a car charger and a portable handsfree. A lot cheaper than a proper incar kit.
AnswerID: 76543
Follow Up By: Gajm (VIC) - Thursday, Sep 16, 2004 at 07:50
Thanks CJ, it's another option
FollowupID: 336375
Reply By: zoom - Wednesday, Sep 15, 2004 at 23:41
The 3105 Nokia cannot take a proper external antenna as it has no plug to accomadate it, some phone shops tell you it can but is done by a passive connection and doesnt work half as well. The older model Nokia cant rember the model does but its the only nokia I believe. Very few of the current models will take one, have a look at the Kyocera phantom or the Hyundai cant remeber the model, if you are into flips there is a motorola also, there is probably some others but a lot wont. The explanation I was given is that Korea where a lot of the phones are made for has a much more substantial network than Australia and less need for high gain antennas.
AnswerID: 76560
Follow Up By: Gajm (VIC) - Thursday, Sep 16, 2004 at 07:52
Thanks Zoom, I am not into the flips, I just want a basic phone that makes calls, don't care about ringtones or games or if it can take pics...try telling that to the dealers tho.
FollowupID: 336376
Reply By: Member - Cocka - Thursday, Sep 16, 2004 at 00:03
I just fitted a Kyocera Phantom. It's dual GSM & CDMA - switches automatically from city to country. I finished up with the car kit but could have had the patch. It's a much tidier outfit otherwise you finish up with a charging lead hanging out of the ciggy hole and an aerial lead lying around.
Must get the dual aerial though. Best was from Laser aerials in Qld. Check here :
http://www.laser-antenna.com.au/ant_SF9DDB_259.htm
I fitted the whole unit myself & couldn't be happier, worth every cent. Supplier - Telstra.
If you have an ABN (number) the call rate plans about half cheaper.
If you need tips on fitting it come back to me.
AnswerID: 76564
Follow Up By: Gajm (VIC) - Thursday, Sep 16, 2004 at 07:47
Thanks Cocka, I will check it out....may have to go the car kit after all.
Did it take you long to fit?...trying to leave this weekend
FollowupID: 336371
Follow Up By: Member - Cocka - Thursday, Sep 16, 2004 at 08:25
If you know what you are doing it can be done in the day OK but, getting the right aerial would be the prob, even if you ordered it today you wouldn't get it until tomorrow, earliest.
You have to run a power supply & earth, set up the mic and a remote speaker, set up a position to locate the phone, fit & run the aerial cable and get a suitable mini coaxial cable connector (the aerial comes with plenyt of cable fitted).
Doing it any other way could cause problems and void the warranty. If you ordered the aerial this morning and could find a professional installer you might make it in time but they charge about $400.oo I have been told.
You could just take the phone and fit it later. It comes with 240v charger only, you may need a ciggy hole charger. It will still work, just not quite as well.
Best wishes.
FollowupID: 336380
Follow Up By: Member - Cocka - Thursday, Sep 16, 2004 at 08:30
There's a cradle thingy that comes with the Kyocera patch kit but you can't charge the phone while it sits in this cradle, it's only good for the antenna connection and doesn't include an antenna.
FollowupID: 336382
Reply By: Will - Thursday, Sep 16, 2004 at 10:32
Hi Gajm, I use a samsung cdma with a external antenna and patch lead, works well and is easily fitted.
Brought the phone thru orange which uses the telstra network when bush and brought the patch lead and antenna at Dubbo thru a dick smith type outfit.
cost about $125 all up plus time to fit. Not hard.
Will
AnswerID: 76603
Follow Up By: Member - 'Lucy' - Thursday, Sep 16, 2004 at 11:51
Morning Will
What model Samsung do you have.
Ken Robinson
FollowupID: 336407
Reply By: Will - Thursday, Sep 16, 2004 at 11:57
Hi Gajm,
it is a samsung SCH N181 I needed a CDMA and this one has a nice blue screen I can see.
Will
AnswerID: 76615
Reply By: Member - Jeff M (WA) - Thursday, Sep 16, 2004 at 14:06
I just whacked a Motorala T730 in with a car kit and a 6db spring base antenna, bloody great, phone was free and genuine car kit was $49 on a $50 plan with Telstra. good deal IMHO.
AnswerID: 76627
Reply By: Richard & Leonie - Thursday, Sep 16, 2004 at 21:59
Search the forum because there are lots of answers already there. Be careful using a patch cable. I am told you can ruin the "motherboard" in your phone. I have a Kyocera 3245. Telstra shop provided a patch cable that I hook up to a GME CDMA antenna. Works well but I only use the setup when going bush and need the extra range. I LEAVE THE PATCH CABLE IN ALL THE TIME I AM BUSH SO AS NOT TO DAMAGE THE PHONE. When I take the patch cable out I do it very carefully.
AnswerID: 76710
