THE INCREASING PRICE OF DIESEL...WHY?
Submitted: Wednesday, Sep 22, 2004 at 09:27
ThreadID: 16472 Views:2816 Replies:13 FollowUps:13
I a little confused! The price of diesel around Canberra seems to be climbing every day at a rate much faster than unleaded petrol...why? After all diesel is much much cheaper to refine. Perhaps someone who works in the pricing department of an oil company can explain why diesel is now on average 10 cents/litre dearer than unleaded. In some instances around here over the past couple of weeks I have seen Diesel at 115.9 and Unleaded at 102.9 (at the same time). Are the oil companies inflating the price of diesel to subsidise unleaded? Perhaps someone has the answer.
Pete
Reply By: Member - Chris M (QLD) - Wednesday, Sep 22, 2004 at 09:29
Gday mate,
Diesel is much cheaper to refine because it's the least refined of all the fuels!
Somone within the industry may have an answer, but it's difficult to believe isn't it!
Chris.
AnswerID: 77395
Reply By: Truckster (Vic) - Wednesday, Sep 22, 2004 at 10:08
" Are the oil companies inflating the price of diesel to subsidise unleaded"
we have a winner.
AnswerID: 77400
Reply By: Member - Jack - Wednesday, Sep 22, 2004 at 10:34
Complaining to fuel companies about the price of diesel is like complaining to your mother in law about your wife. Truckster got it in one. : )
Jack
AnswerID: 77406
Reply By: Des Lexic - Wednesday, Sep 22, 2004 at 12:11
There is only one reason why Diesel is dearer than unleaded.
Because we are being ripped off with dozens of bleep ant excuses.
PS The govt likes the extra revenue as well so they won't do anything about it.
Not being political because the other side is just as bad.
AnswerID: 77414
Follow Up By: Truckster (Vic) - Wednesday, Sep 22, 2004 at 13:16
Im suprised the transport industry isnt screaming like a little biatch. Wheres the TWU (totally worthless urine)....?
FollowupID: 337014
Follow Up By: flappan - Wednesday, Sep 22, 2004 at 13:21
I would think the Transport Industry doesn't get TOO fussed , because in 99.9% of the cases , it would be a tax deduction anyway . . . or they simply pass the cost onto customers . . . or . . . both.
FollowupID: 337019
Follow Up By: madcow - Wednesday, Sep 22, 2004 at 13:36
Dont forget that transport and heavy equipment operators can claim back the tax on diesel with the BAS. Therefore the ordinary consumer now picks up the difference and pays more. It used to be the other way around before the tax deductability was introduced. Diesel around Wodonga is $1.12 at the moment.
FollowupID: 337021
Follow Up By: Truckster (Vic) - Thursday, Sep 23, 2004 at 12:07
Passing onto consumers - agree..
.. but the snowball effect is food, etc costs rising, which they dont seem to be.
Noting that We should all email Todaytonight for their "do you have a story for us" page.
FollowupID: 337136
Reply By: Tim (VIC) - Wednesday, Sep 22, 2004 at 12:31
All fuels are a rip off
I was told that we cannot refine the diesel here to the correct standard so we ship it off shore get it refined and bring it back.
Is this correct ?????
Then we pay 44 cents / litre in tax
what hope is there
Tim
AnswerID: 77416
Follow Up By: Truckster (Vic) - Wednesday, Sep 22, 2004 at 13:12
Nope.
FollowupID: 337013
Reply By: Austravel - Wednesday, Sep 22, 2004 at 13:21
I didn't think Australia made any diesel fuel, the report I read it's all imported. Depends on the type of crude oil you have as to what you can get from it.
AnswerID: 77419
Follow Up By: Truckster (Vic) - Wednesday, Sep 22, 2004 at 23:14
Its made at Kurnell, ask wayne ;) he works in the diesel plant there
FollowupID: 337084
Follow Up By: Austravel - Thursday, Sep 23, 2004 at 08:30
Truckster,
Not doubting you, it's something I read a number of times. Is it maybe that we don't have our own crude to make diesel and we import this to crack our own here?
FollowupID: 337096
Reply By: flappan - Wednesday, Sep 22, 2004 at 13:28
I borrowed this off the Overlander forum.
Quote:
The "crude oil" pumped out of the ground is a black liquid called petroleum. This liquid contains aliphatic hydrocarbons, or hydrocarbons composed of nothing but hydrogen and carbon. The carbon atoms link together in chains of different lengths.
It turns out that hydrocarbon molecules of different lengths have different properties and behaviors. For example, a chain with just one carbon atom in it (CH4) is the lightest chain, known as methane. Methane is a gas so light that it floats like helium. As the chains get longer, they get heavier.
The first four chains -- CH4 (methane), C2H6 (ethane), C3H8 (propane) and C4H10 (butane) -- are all gases, and they boil at -161, -88, -46 and -1 degrees F, respectively (-107, -67, -43 and -18 degrees C). The chains up through C18H32 or so are all liquids at room temperature, and the chains above C19 are all solids at room temperature.
The different chain lengths have progressively higher boiling points, so they can be separated out by distillation. This is what happens in an oil refinery -- crude oil is heated and the different chains are pulled out by their vaporization temperatures.
The chains in the C5, C6 and C7 range are all very light, easily vaporized, clear liquids called naphthas. They are used as solvents -- dry cleaning fluids can be made from these liquids, as well as paint solvents and other quick-drying products.
The chains from C7H16 through C11H24 are blended together and used for gasoline. All of them vaporize at temperatures below the boiling point of water. That's why if you spill gasoline on the ground it evaporates very quickly.
Next is kerosene, in the C12 to C15 range, followed by diesel fuel and heavier fuel oils (like heating oil for houses).
Next come the lubricating oils. These oils no longer vaporize in any way at normal temperatures. For example, engine oil can run all day at 250 degrees F (121 degrees C) without vaporizing at all. Oils go from very light (like 3-in-1 oil) through various thicknesses of motor oil through very thick gear oils and then semi-solid greases. Vasoline falls in there as well.
Chains above the C20 range form solids, starting with paraffin wax, then tar and finally asphaltic bitumen, which used to make asphalt roads.
All of these different substances come from crude oil. The only difference is the length of the carbon chains!
END:
AnswerID: 77420
Follow Up By: Des Lexic - Wednesday, Sep 22, 2004 at 16:57
Flappan, are you a politician, blinding us with science. LOL
Seriously, a very interesting read. Thanks
FollowupID: 337046
Reply By: Banjo (SA) - Wednesday, Sep 22, 2004 at 15:08
Its all marketing (as a science) - the oil companies have people that study prices and sales trends - they would have worked out years ago that Aussie's love their cars and will cut back on other expenditure before they cut back on fuels. This would all be clearly evident in the market trends. My guess is that they think we will wear higher prices and maintain usage IF we think there is a fair cause behind the rises (Geroge W and Iraq etc). IF they think that we think they are simply ripping us off, they would drop their margins to win share etc. - nothing will change re their fully exploitative attitude until we all start buying less and staying home (gulp). Evidence of this exploitation is found in fuel being dearer from Thursday arvo's when skint people get their first (payday) opportunity to fill up.
AnswerID: 77434
Reply By: Rob! - Wednesday, Sep 22, 2004 at 15:36
Companies, big or small, exist for only one reason. Profit. The more the better. They are not a charity. They will say that "they have responsibilty to the shareholders", or in the case of small companies " provide for their kids." They have no moral values and we shouldn't expext them to have any.
Like with any bussiness, you sell your product for AS MUCH AS YOU CAN and the prices will be dictated by the old supply and demand.
The best way to half the cost of your fuel is to buy a suzuki swift (or become a shareholder in shell). If we are not prepared to do that, then we must pay the price.
Why does a dog lick it's balls?
R.
AnswerID: 77438
Follow Up By: Truckster (Vic) - Thursday, Sep 23, 2004 at 10:46
Because they are sweatty or itchy?
FollowupID: 337115
Reply By: rolande- Wednesday, Sep 22, 2004 at 16:34
Or may-be the oil companies have seen the latest sales which show 24% of all vehicles sold now are 4WD's. I refuse to use the Yankism, "SUV". More diesels being sold than ever before so a good chance to make a profit.
Rolande
AnswerID: 77442
Reply By: Member - Brett H (QLD) - Wednesday, Sep 22, 2004 at 18:15
I was in the transport game at the beginning of the GST implementation and know that I was eligible for a fuel rebate of 26 cents per litre because the truck was over 26 ton. That is why the transport operators aren't hopping upa nd down.
I think this still is in place,.
AnswerID: 77456
Follow Up By: rickwagupatrol - Wednesday, Sep 22, 2004 at 20:32
26 cents per litre ??????????????????
where,,,when. i dont think so. and that nowhere near covers the cost of fuel nowadays.
try 18 cents per litre.
and as for the rest of you lot.
i own a truck,,,,there is a lot more to running a truck than just fuel.......why dont some of you ring your local licensing bureau,,,and ask how much it is to rego a truck today.
or ring an insurance company and get a quote on full coverage, plus workers comp and public liability....
then there is all the other costs involved, as well as the taxes the mongrel government take.
there are very few owner/drivers who get to see a fuel levy,,,,the big boys usually gobble it up. and believe me,,,,each and every truckie out there is starting to do it real hard.
dont go off with half truths and inuendo,,,,get the facts,,,then discuss this problem.......
because very soon,,,,,the problem is comming to a store near you.
its about time the public got behind the transport industry and demanded that the cost involved in owning and operating a truck started to come down,,,,,,,,,,,,,,,,or we can simply make the public pay our costs.
rick.
FollowupID: 337066
Follow Up By: rickwagupatrol - Wednesday, Sep 22, 2004 at 20:36
oh,,,and dont forget that alot of us are still being paid pre 2000 rates,
which means that we are only just managing to feed and cloth our families.
FollowupID: 337067
Follow Up By: Member - Brett H (QLD) - Wednesday, Sep 22, 2004 at 21:10
Calm down mate. Not having a go. I recall that there was a rebate offered by the FED govt after the GST was implemented and the rebate amount was relative to the size of the truck.
As for rates, if you can't make a living out of the trucking business do something else....easy.....anyway the subject is the fuel price.
I was suggesting that the transport industry may not be feeling the full impact of the bowser price due to the rebate... If you don't get a rebate tell me and I will forget about it.
I am an ex owner driver mate so I know the difficulties I made more money by increasing my rates and doing less work and inturn spending less money on fuel, tyres , servicing etc etc. The trouble with most owner drivers is that they are so worried about where the next dollar is coming from that they accept jobs that don't provide enough profit to cover all of the real expenses which are a lot more than the day to day expenses.. anyway cheers
FollowupID: 337075
Follow Up By: Truckster (Vic) - Thursday, Sep 23, 2004 at 10:48
Knew there was a reason I was never an owner driver...
FollowupID: 337116
Reply By: michael - Thursday, Sep 23, 2004 at 09:55
Yes Pete, I have believed exactly what Truckster says for some years now. It is especially unsubtle around unleaded price war times. It hurts to know you appear to be funding the battle. What to do or what can be done about it by diesel consumers is the big question. Maybe someone through this forum can come up with a strategy to give diesel users representation through a form of lobby to Govt.
In the interim I disregard shopper dockets and support the GULL over here in WA as they are consistently cheaper and fairer than the big outlets. There is a BP just down the road charging 113.9 c/l today and is always way above GULL Wangara or Kingsway. I would rather drive 10Km to buy diesel and unleaded from nearest GULL than from those other robbing barstewards. Mustering other consumers to make some kind of stand, at the very least symbolic, is another matter. Most people are either too lazy to be more selective in choice of supplier or have defeatist attitude and always think nothing can be achieved against the big boys -and girls.
Makes me wonder how we Aussies ever found those brave fellas to halt the nips on the Kokoda Trail. Thanks again to those who didn't give up.
DRC
AnswerID: 77519
Reply By: Mike-TS - Monday, Sep 27, 2004 at 22:11
Theoretically diesel is cheaper than petrol to make. However, there is one complication - crude oil has sulphur in compound form and when you refine the crude sulphur concentrates in the heavier ends - petrol ~c8, diesel ~c10.
The government have placed strict limits on sulphur content on fuels and it is getting stricter. Therefore as diesel attracts sulphur it costs a fortune to remove it.
Also, petrol stockpiles are probably greater than diesel stockpiles so petrol can adsorb the swings in oil prices but diesel is slugged straight away as crude on the market makes it to your tank quicker.
Oil price is up to US$50 per barrel so be prepared for higher costs in the future.
AnswerID: 78003
