wheel noise
Submitted: Thursday, Sep 23, 2004 at 14:41
ThreadID: 16508 Views:1956 Replies:3 FollowUps:0
i have a noise coming from the driver side front wheel when turnig left into a corner etc at a speed anywhere between 30 to 60 or so klms, it sounds metallic, iv'e been told there is nothing wrong with the bearings, any thoughts??
gu 2000 patrol, 78,000 k, regularly serviced, thanks, Adrian.
Reply By: tour boy - Thursday, Sep 23, 2004 at 14:57
check your brake pads as the wear strip will contact the disc rotor well before the pads wear out. Sometimes when they are close to touching, the rim/ rotor flex when cornering will allow the wear indicator to touch slightly. This is metal to metal.
Tour Boy
AnswerID: 77555
Reply By: Bros - Thursday, Sep 23, 2004 at 19:56
G'day ace,
Need more input on the type of metallic noise emanating from your vehicle.
Clunk, ping, screech etc etc.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 77598
Reply By: Cougar (WA) - Thursday, Sep 23, 2004 at 23:42
I go with "tour boy" on that one. Had same problem on lady Cougars car changed discs, no more noise.
AnswerID: 77643
