Mounting CB on Landcruiser 100
Submitted: Saturday, Sep 25, 2004 at 11:35
ThreadID: 16553 Views:8815 Replies:10 FollowUps:0
Recently picked up a Landcruiser 100 series and wondering where to put CB.
I have a Uniden UH090 (FM/AM). (I've now transferred it out of 2 vehicles and it's still as good as the day I bought it!)
On Jackeroo I had it next to drivers seat on consol, on Defender I had it on back of cubby box.
Where do people mount the CB's on LC100?
Thanks.
Reply By: Rossco100series - Saturday, Sep 25, 2004 at 15:40
Mine is mounted on the driver side of the centre console. But Mike mount it where ever you are happy.
Rossco
AnswerID: 77813
Reply By: obone - Saturday, Sep 25, 2004 at 17:27
I stood around scratching my head on a few occasions trying to solve the same problem. Couldn't come up with a suitable position, so didn't bother. Can't really say I miss it either. If I had no choice, I guess I'd put it at the rear of the consol box
on a bracket that still allowed the lid to open !
AnswerID: 77817
Reply By: Tritondriva - Saturday, Sep 25, 2004 at 17:51
You really need a detachable face unit, but if you are like me, and dint want to buy one, you either have to put it in the way on the side of the console, in a dash pod, in a roof console, or like me, double sided tape (the proper stuff) to the top of the dash. I agonised over it for ages, and the GPS is mounted the same.
I have a dash mat, and just cut out a hole the size of the radios mounting bracket where I wanted it, (I have an Icom radio, and they have a large bracket, with lots of surface area) cleaned the area with metho, then stuck the bracket on. Wires and coax are routewd under carpet dash mat to the pillar, where Ive routed the cables down behind the trim.
Altho Im not a fan of the asthetics of this, it doesnt look that bad, and is brilliant to use, and so far, I have had no problems at all with vibrations or anything else. (the tape is supposed to hold like 80 kilos or something, so Im guessing my biggest problem is going to be removing the tape if I ever need to)
AnswerID: 77820
Reply By: Jarrod - Saturday, Sep 25, 2004 at 20:50
Hey Mike, I have a std 100, 2002, didnt relize how hard it was to store /mount stuff untill i owned this thing. I ended buying an out back roof console. Bit of a bugger having to shell out a few more hundred $$ just to find somewhere to install the cB, but it turned out being a good buy, - looks "Factory", extra drop down shelf for wallet, sunnies etc.
Mate has a GXL, we mounted his UHF on the back of the cnr console. sort of "piggy backed " i spose..
Jarrod.
AnswerID: 77835
Reply By: Croozer - Saturday, Sep 25, 2004 at 21:04
Mike,
I had a gme 4400 to mount into my gxl100 but could not really find anywhere good to mount it, unless I bought a dash pod. My solution was I sold the 4400 on ebay and bought a 3400 (remote head unit) also on ebay (similar $$$), problem solved with the head unit mounted to the centre console using double sided tape, perfect.
Stu
AnswerID: 77836
Reply By: Bob&Deb - Sunday, Sep 26, 2004 at 08:08
We have a 100L/C Poverty Pack, mounted our Uniden CB/UHF in the centre of the dash. Below the standard radio there is a small removeable fascia piece,behind which is a hole/box incorporated into the framework that holds the whole dash panel in place.To acess this area just unclip the face piece of the centre of the dash.QED.
Keep Wandering
Regards Bob
AnswerID: 77855
Reply By: JimB - Monday, Sep 27, 2004 at 07:34
Ay Mike,
I have a 100GXL and remote head GME 3400. I removed the cover from the front of the ash tray and mounted the bracket and remote head on that. Now I can still use the ash tray (still slides in and out) and will replace the cover when we move on from this vehicle. Very convenient, no holes to repair later.
JimB
AnswerID: 77919
Reply By: Member - Cruisin (QLD) - Monday, Sep 27, 2004 at 14:21
Hi Mike
On my 100 Series I had replaced the original Double Din stereo with a single Din MP3 player. This freed up a single Din space just nice for the GME 4400 UHF.
Looks like a factory install and is in the perfect space for operation.
Cheers Cruisin
AnswerID: 77954
Reply By: Ozman - Monday, Sep 27, 2004 at 17:14
Cant beat the gme remote head 3400. andrews comms for $429! Fit the unit in the hidden in the console and the remote head with double sided tape on the side. PERFECT!
Bloody toyota 100 series - no map pockets, etc......all the space but no where to put anything!!!!!
AnswerID: 77966
Reply By: Member - Bob et Joëlle (NSW) - Tuesday, Sep 28, 2004 at 09:02
Mike
We have a GME 3200 - it is mounted on the right of the stearing wheel just above the fuel, bonnet catches. Works well there but only the driver can use it easily. If we were doing it again would look at overhead console.
AnswerID: 78025
