Site Search
Section Image
Smoking Pajero
Submitted: Monday, Aug 05, 2002 at 00:00
Ross
I have a 94 NH 2.8D (no turbo). With winter and cold mornings, after start up, blows a lot of white smoke and misses badly. Only lasts for a short time then is ok. Had glow plugs checked and told they too were ok. New problem. Driving along with engine nice and warm when the vehicle feels to be under load (towing a trailer), motor misses a beat and a burst of white smoke fom exhaust, then back to normal. Any thoughts.
Advertisement
ThreadID: 1656 Replies: 7
Views: 1094 FollowUps: 2
AnswerID: 5432   Submitted: Tuesday, Aug 06, 2002 at 00:00
CHRIS replied:
I wouldn't mind betting you have a blown head gasket-cracked head or a warped head that is allowing water into the cylinder.Are you losing any water.
Reply 1 of 7
FollowupID: 2350   Submitted: Tuesday, Aug 06, 2002 at 00:00
Ross posted:
Problem is that nothing else is out of place and not using water. oil is clean ands no visable problems in the engine room.
AnswerID: 5433   Submitted: Tuesday, Aug 06, 2002 at 00:00
johnf replied:
May be time to get a Prado - never missed a beat.
Reply 2 of 7
FollowupID: 2351   Submitted: Tuesday, Aug 06, 2002 at 00:00
Ross posted:
Haven't won the Paris to Dakar rally either!!!
AnswerID: 5448   Submitted: Tuesday, Aug 06, 2002 at 00:00
scotto replied:
Sounds like you have more than 1 problem. Your glow plugs might be OK but what about the timer? Could be not suppling correct volts or for right amount of time. Power loss could be anything, ring SMS on 02 9714 2500 as they have a diagnostic engineer who can advise you for free.
Reply 3 of 7
AnswerID: 5460   Submitted: Wednesday, Aug 07, 2002 at 00:00
kezza replied:
White smoke is your clue - seems to be a fuel delivery problem, running lean for some reason momentarily check filters especially the tiny banjo filter in fuel pump also injectors "may" need a service. - not much can go wrong really apart from this. Also timing problem may cause this but too erratic (still stranger things............)
good luck
Kezzza
Reply 4 of 7
Activities Index
Islands Reef and Dive 3 days Islands Reef and Dive 3 days
The Whitsundays - QLD
Beyond the islands and their fringing coral reef lies the outer Great Barrier Reef and together they
Beginners Intro. to dinghy sailing at Balmoral Beginners Intro.
Sydney - NSW
On one of Sydney Harbour's premiere beaches, you will be taught a series of techniques to guarantee
Rainforestation Nature Experience Rainforestation Nature Experience
Cairns and Tropical North QLD - QLD
Get back to nature with this experience.
Hot Stone Massage Therapy - 90 minutes Hot Stone Massage Therapy - 90 minutes
Sydney - NSW
Experience a hot stone massage therapy and feel completely relaxed in your mind, body and spirit.
Book Now - Things To Do
AnswerID: 5482   Submitted: Wednesday, Aug 07, 2002 at 00:00
ray91 replied:
hi Ross I to would like to know why the white smoke.My nissan patrol 2.8 turbo diesel has started to do exactly the same thing even missing a beat when warm.I have tried the local diesel garage they say the injectors need servicing but they always say that whatever is wrong
Reply 5 of 7
AnswerID: 5858   Submitted: Tuesday, Aug 20, 2002 at 00:00
steve replied:
I own a MQ diesel and is doing the same thing lucky for me i work with diesel machanics they told me that the injectors aren't operating properly in the cold mornings (it doesn't happen in the summer) there spray patern is uneven and the droplets are to big, and with a cold diesel engine they don't burn properly wich causes the white smoke and running ruff until it all clears and the injectors work better. the glow plugs are another thing that will cause this and more than likely if the smoke clears up and goes black when under load or changing through the gears. So don't forget that white smoke is unburn diesel fuel and blue smoke is oil burning i hope all this makes sense and helps
also there is a lot more to be told about this problem what i have said is rather quick and simple.
Reply 6 of 7
AnswerID: 5859   Submitted: Tuesday, Aug 20, 2002 at 00:00
dennis replied:
you dont mention kms or service history. any inspection should include things such compression testing & cylinder leakage. white smoke is associated with incomplete fuel combustion and can be caused by poor compressiion , incorrect fuel timing or maybe a primary fuel pressure problem in the injection pump. ps i dont think any STANDARD pajero ever did very well in the P-D
Reply 7 of 7
