84 Hilux electrical
Submitted: Wednesday, Sep 29, 2004 at 15:33
ThreadID: 16648 Views:1714 Replies:3 FollowUps:2
I have a 84 dual cab old but honest she has an electrical problem when you turn the key on the glow light used to come on and heat up and then go out automatically.but now for some strange reason you have to manually turn the key just that little bit further not quite to start position for the glow plugs to heat up and then it slowly goes out.I would really apprciate some feedback guys.I usually like to do my own work on the old girl as sometimes you just cant trust others.But this one has me beat.
Thanks.
Dazza
Reply By: Kiwi Ray - Wednesday, Sep 29, 2004 at 15:48
Hi Dazza
It could be that your ignition switch has some wear internally and not making contact.
Ray
AnswerID: 78228
Follow Up By: deb_daz - Wednesday, Sep 29, 2004 at 15:55
Thanks Ray I will check it out.Not a really big problem I know but just an annoying one.
Dazza
FollowupID: 337807
Reply By: ColinD - Wednesday, Sep 29, 2004 at 18:46
Yep, sounds like the ignition switch needs replacing.
AnswerID: 78255
Reply By: navaraman - Wednesday, Sep 29, 2004 at 20:04
As daft as it sounds I had a problem starting my car with occaisional glow plug problem. Turned out to be wear in the key. When i used the spare key problem disappeared. I'd try it first, you never know.
AnswerID: 78267
Follow Up By: deb_daz - Thursday, Sep 30, 2004 at 12:58
I really appreciate all who have replied with info.I will write this one to reply to all,it seems that you all have the same idea the switch.So I will check it out.This is the best forum I have been in ,you all are very forth coming with info for just about anything.So keep up the great site and I really appreciate all the info I receive.
Dazza
FollowupID: 337886
