40-Channel 2-way CB Radio TRC-474 information
Submitted: Wednesday, Sep 29, 2004 at 18:34
Jonoc
Ave
I found this old "TRC-474 40-Channel 2-way CB Radio" I have fitted it to the hilux and i don't have any instructions or anything, can somebody help me out ie give me a link to a website with operational instructions.
Oh, does anyone know what aerial (cheap and unbreakable) to put on it as i don't have a clue , plus i don't know what the "db" in 6.5db and 4.5db means.
Cheers Jonoc
Reply By: Jonoc - Wednesday, Sep 29, 2004 at 18:44
More information (I only have the box no other info)
It has rude 1980's graphics on the front of a blue box.
Made by Realistic
Cat. No. 21-1539
3 flick up and down switchs 4 small knobs one large knob
and 8 little LED light indicator thingy's
Jonoc
78254
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 29, 2004 at 18:55
Hey Jono, Glad your not a Commercial Pilot!!! (:o)
337824
Reply By: Michael ( Moss Vale NSW) - Wednesday, Sep 29, 2004 at 18:50
Hi there, Its obviously an old 27mhz unit, Dicko or Jaycar both have aerials and bases, combinations for under $25 with leads. But you must get the SWR correct or you will burn out the final transistors in the CB. (standing wave ratio). This is done with a SWR meter and snipping the top of the antennea or adjusting
the tip of the antennae , dependind on the type of antennae. Ask the Dicko guys or the Jaycar fellas about this. see how you go,,, Michael
78256
Follow Up By: Jonoc - Wednesday, Sep 29, 2004 at 18:52
i have A base on the top of the ute already i just need an aerial.
can i just wack an aerial on it?
337822
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 29, 2004 at 18:57
Ok, just get aerial, from the 2 big boys, under $20, 27mhz and get someone to "SWR" it. Hope it works for you!!
337827
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 29, 2004 at 19:01
SWR should be optimum 1:1 but up to 2:1 is ok, you can listen but dont transmit without having it checked for correct SWR.
337828
Reply By: locallaw - Wednesday, Sep 29, 2004 at 19:22
Gidday,If it is a 27mhz sell it and buy a UHF.Very few people use 27 mhz anymore.I think 95% of travellers use UHF.On 27 mhz the antenna has to be tuned to the radio and on UHF just wack the antenna on and away you go(pre tuned).
Seeya Locallaw
78261
