DUAL BATTERY SET UP
Submitted: Saturday, Mar 31, 2001 at 00:00
PAUL
JUST WOULD LIKE TO ASK OPINIONS ON DUAL BATTERY SET UP FOR GU.PATROL, RUNNING ENGEL 39L.FRIDGE & WARN 9000 WINCH. IE BEST BATTERY TYPE & CONNECTIONS,WHETHER SOLAR PANELS ARE A MUST OR CAN BE AVOIDED.
Reply By: mark Callaghan - Sunday, Apr 01, 2001 at 00:00
Hi paul
Firstly your winch should be connected to your main battery and the motor kept operating during winching.
As for the dual battery - i have just fitted a new fangled set up to my 80 series using the Odyssey Extreme battery system
Basically, i fitted 2 of the same type of battery. Each battery is BOTH a cold cranking CCA and a deep cycle in one unit. They can accept full charge and can be recharged in about 40 minutes as opposed to a day for a normal deep cycle battery
I dont know of anyoine else who has had any experience with them but i am willing to give it a go. each battery is around the $400 mark making them very expensive. However, i cant afford to have problems with my electrical system as i run
tag along tours.
If they are only 1/2as good as the advertising guff, then i will be very happy.
324
