Cheap 12V air compressors
Submitted: Sunday, Oct 03, 2004 at 13:10
Michael
While I can probably guess the answer, has anyone found any of the cheap and cheerful 12V air compressores (for pumping up tyres) on the market to be any good ?
Any that I have used in the past have invariably lasted about as long as it takes to lose the receipt.
I suspect that in this area, you get no more than you pay for.
Anyone know of an exception to the rule ?
Reply By: sub - Sunday, Oct 03, 2004 at 14:54
michael ,Ihave a blue tounge 2 which i think is great but you pay the money for them. my father has a truck air wich cost about $100 from one of the auto shops afew years ago and while it takes about the same time to re inflate a tyre his dosent get the same amunt of use as
mine as he doesent do much sand driving. so how long they would last with constant use i dont know.
78667
Follow Up By: Member - Jeff M (WA) - Tuesday, Oct 05, 2004 at 14:36
Yep, used my Boue Tounge IV a few times now, even doing eight tyes a time, bloody fantastic.
338357
Reply By: Steve L - Sunday, Oct 03, 2004 at 16:57
I have one of the Supercheap Auto ones - usually around the $120 mark, but often on special for less than $100 - and find it's very good. I know a lot of people with this model and they pretty much all swear by it.
Of course, if you're re-inflating 4by tyres every day after beach/sand/offroad driving it won't last as long as the more expensive brands, but for a few uses a month I've found it worthwhile. Not too much slower than some expensive ones either - at least for 4 tyres, if you're doing other peoples tyres too, then again go for something more expensive.
78672
Follow Up By: Savvas - Sunday, Oct 03, 2004 at 17:06
I have one of these as
well and find it suits my purposes
It's horses for courses, really. depends how often you are going to need it and what sort of duty it will be called upon. For high volume work, get one of the dearer ones.
However having said that, if you plan on spending $300 or $400, you can get 3 or 4 of the Supercheap ones and have spares!
Your choice.
338139
Follow Up By: Member - Jeff M (WA) - Tuesday, Oct 05, 2004 at 14:38
I've had two Supercheap "cheapies", did'nt bother taking the second one back, I saved up and bought a Blue tounge, best thing I ever did. No comparison.
338358
Reply By: Truckster (Vic) - Sunday, Oct 03, 2004 at 17:25
What do you call cheap?
78681
Reply By: theshadows - Sunday, Oct 03, 2004 at 20:12
ive got two 12 volt ones from Kmart ...$12 each. One in each car and yes Ive used them about 5 times and the are slow but work a treat. Ive got a $150 one for when I go and drop my tyres on
the beach
shadow
78694
Reply By: Member - Alan S (NSW) - Tuesday, Oct 05, 2004 at 10:08
Check out ebay:
link text
I bought one of these, not expecting much but it seems happy to pump up 8 Landcruiser tyres in about 20 mins without any issues. I guess it'll do fine for occcasional use.
Not sure how cheap you mean by cheap but these are now selling for in or around $120-$140 + postage.
Hope this helps,
78896
Reply By: pathfinder - Tuesday, Oct 05, 2004 at 13:34
Truckair at about $90 was hopeless. Supercheap one at about $120 has proven to be very good and very quiet. They also now have a much larger unit for only $165...
78914
Follow Up By: Davoe - Saturday, Oct 09, 2004 at 16:06
sorry to hear that I have had
mine for 4 years with no worries sure they are a bit slow but that is why they dont cost $300 and they will run continuosly without overheating
338900
Reply By: Member - Jeff M (WA) - Tuesday, Oct 05, 2004 at 14:42
IMHO stay away from the supercheap ones, I got stuck with tyes at 12psi and no air when my second one failed. Go a gooden, you'll be so happy you did. It's hard to justify it but when you've pumped your tyes up in 10 minutes and are back on the road you'll be so glad you went a gooden. It's a peice of mind thing too.
78928
Reply By: Muddy 'doe (SA) - Tuesday, Oct 05, 2004 at 22:26
Hi Michael,
I got the Bushranger Pro-Air which is their middle model between the little one and the full-on Max-Air. I got it at Ray's when they had one of their regular 20% off sales so it cost me $199.95 (normal retail $250)
Used it for the first time over the weekend and was really happy. Inflated my 265/70R17 tyres from 28psi back up to 38psi in about 2 minutes per tyre.
Seems of good quality construction and did the job
well. Comes in a good canvas bag and does not take up too much space.
Given the number of times I will use it (maybe 10 times a year) I could not justify the extra $150 odd for the Max Air which has a coiled hose and few extra bits and about 40% more flow rate. The Pro Air is just right for me.
It is about the price of 2 of the Supercheap jobs but I will bet that it lasts more than twice as long as
well as get the job done in half the time!
Muddy 'doe
79004
