Site Search
Section Image
brake fluid for 100 series-must use dot 3 not dot4
Submitted: Monday, Oct 04, 2004 at 07:49
fozzy
word of warning for 100 series owners for brake fluid
must use dot 3 brake fluid not dot 4
dot 4 is not compatable with the seals causing them to swell and the pedal to stick
replacing master cylinder is quite expensive-think around $2500 for part
dot 3 is a "genuine" toyota brake fluid and another compatable one is valvoline.
most others are dot 4 range
Advertisement
ThreadID: 16763 Replies: 8
Views: 1612 FollowUps: 2
AnswerID: 78737   Submitted: Monday, Oct 04, 2004 at 08:47
Austravel replied:
I thought dot 3 and dot 4 were interchangable ie dot for is just an improvement.
Reply 1 of 8
FollowupID: 338197   Submitted: Monday, Oct 04, 2004 at 08:57
fozzy posted:
austravel
i know nothing about brake fluids-just taking info from a september release from vacc techtalk given to me by a bloke from toyota dealership.
i did have a 100 series which had the brake master replaced with new one(5 yr old car) done under warranty(very lucky) which had brake pedal sticking which could have been caused by brake fluid(who knows) as there has been issues with the master cylinders in past.
possibly(most likely) the brake fluid has been found to be problem)
AnswerID: 78740   Submitted: Monday, Oct 04, 2004 at 09:01
Austravel replied:
I'm not positive either, just what I read on the labels. It's pretty bad if it's the case for all vehicles. I'll certainly be looking at mine when I get home as most places would source seal, buckets, o-rings from similar manufacturers so it may effect many vehicles not just toyota.
Reply 2 of 8
AnswerID: 78745   Submitted: Monday, Oct 04, 2004 at 09:40
rob1 replied:
Same with Nissan Patrol. Cap on the brake and clutch reservoir says use Dot 3. Manual says use Dot 3 or Dot 4. Asked the Nissan guys and they gave me the "Nissan Ultra" brake fluid. Guess what? ... it says Dot 4 on the bottle. So go figure..........
Rob
Reply 3 of 8
AnswerID: 78754   Submitted: Monday, Oct 04, 2004 at 11:00
theshadows replied:
Dot 3-4 are interchangable. dot 4 is the upgraded item with a higher temperture range. As far as I know valvoline hasn't marketed a dot3 fluid for sometime its a dot3-4 spec item.
Dot 5 is the problem its a silcon based item thats incompatible with most seals used these days.
BTW why would you pay $2500 for a master cylinder when appox $650 is the listed part number or $250 for a generic item .and a seal kit is $85 appox.Mind you add the fuild tank and seals kits for all the calipers .Have you abs because the modul would have to be stripped and cleaned as well.
shadow .... heresay is a dangerous rumor.
Reply 4 of 8
FollowupID: 338209   Submitted: Monday, Oct 04, 2004 at 11:17
fozzy posted:
shadow
may be worth a call to your local dealer re price of mastercyclinder for 100 series with abs(sorry my mistake in mentioning that fact)
also hard to go past info from vacc and peddled by the toyota dealers and not rumor but everyones entitled to opinion and i know i will only be putting in dot 3 as specified on the resevoir as well-good luck if yours is 100 series
as with most stuff here its up to reader to interpret and follow up the facts
Activities Index
Bondi Private 1.5 Hour Surfing Lesson Bondi Private 1.5 Hour Surfing Lesson
Sydney - NSW
Experience Australia's greatest surf school on Australia's Bondi beach!
WRX Turbo Rally Extreme Drive 16 Laps + 1 Hot Lap WRX Turbo Rally Extreme Drive 16 Laps + 1 Hot
Gold Coast - QLD
Rally driving - you've seen it on TV, so stop thinking about it and do it!
Le Relais Bressan Lunch Trike Ride for 2 Le Relais Bressan Lunch Trike Ride for 2
Sunshine Coast - QLD
Imagine riding on a Harley Davidson trike through the quaint villages and lush rolling hills of the
Beach Tandem Skydiving - Adrenalin Shot 12,000ft Beach Tandem Skydiving - Adrenalin Shot 12,00
Want the rush of your life and a really idiotic grin that lasts for days?
Book Now - Things To Do
AnswerID: 78805   Submitted: Monday, Oct 04, 2004 at 19:47
theshadows replied:
Price was from wynnum toyota brisbane.You dont want to buy the complete unit including the booster.Its only a master cylinder its not the complete unit.
The unforunate thing is when people in the game should know what they are talking about .For some reason they dont and enjoy scare mongering.One of the classic pieces of advice is "if you car is not service buy a Franchise dealer and use genuine parts we will not accept warrienty of the vechile".
This is the biggest load of bunk going around.The trade practise act enforces the manufactor to warrant all repairs no matter what brand of aftermarket parts used.
{Note if the after market part fails then the consumer must then recover his expences from the part manufactor.} e.g. you throw a cam and timing chain.The manufactor cannot say "you have a non genuine oil filter there for I think its oil starvation problem.go fish" or "you have a non genuine themostat and your motor has over heated you gopt to pay up." trade practices act protects you from this.
As for the VACC I dont mind they couldnt find the bent chassis in a GD300 merc I was going to buy,I didnt mind that they didnt find all the rust in the firewall.But I want to know is what they did for 2 hrs with the truck on their host and how the hell they didnt find the blown rear brake light is beyond me . BTW no they didnt get $130 for the inspection.
Unfortantly now there is half a dosen people now going about sprouting the dot 4 is no good for 100 series and how it will damage the cars.
But the best thing is with this forum is that now 30 or more people have learnt that asking a question i.e "is this true because such and such told me" on this forum will steer them in the right direction.
Your never to old to learn.
shadow
Reply 5 of 8
AnswerID: 78905   Submitted: Tuesday, Oct 05, 2004 at 11:44
Rigor replied:
With regard to the Dot 5 Silicone brake fluid . I have used silicone in all of my vehicles for the last 20 years with no problems at all . My 1976 volkswagen still has all the original hydraulic components , the only things I have changed are pads and shoes . The strength of silicone fluid is its ability to exclude any moisture from the system thereby preventing any corrosion which is the only thing that will cause damage to the rubbers . I swear by the stuff but please adhere to the vehicle manufactures advice if in doubt , particularly with ABS (not recomended )
Reply 6 of 8
AnswerID: 78964   Submitted: Tuesday, Oct 05, 2004 at 19:54
Patroleum replied:
Fozzy,
I doubt that you could even buy dot3 anymore. It's very old spec now.
Reply 7 of 8
AnswerID: 78972   Submitted: Tuesday, Oct 05, 2004 at 21:05
Member- Peter & Mrs Peter, Lez replied:
Owners manual saya Dot 3, for what its worth.
Reply 8 of 8
