GU motor designation
Submitted: Tuesday, Oct 05, 2004 at 09:31
ThreadID: 16798 Views:3048 Replies:4 FollowUps:14
I have a 4.2 turbo GU 2002. Does anyone know what the motor or vehicle code is as per the log book. It designates service items to specific vehicles such as only do filters for D22, Y61, YD, ZD etc. What is this vehicle??????
Reply By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 09:33
Y61 is the model of your vehicle. Y60 was the GQ...heck I hope I'm right!
AnswerID: 78887
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 09:34
Thanks Chris
FollowupID: 338288
Follow Up By: 80scruiser - Tuesday, Oct 05, 2004 at 10:04
Definetly a Y61.
The D22 etc is for other vehicles such as the Navara.
Nissan use the one book for several vehicles.
Your engine should be a TD42 for a naturally aspirated diesel
or a TD42T if it is turbo.
Scott
from Lonards Automotive Repairs
www.lonards-automotive.com.au
FollowupID: 338292
Follow Up By: 80scruiser - Tuesday, Oct 05, 2004 at 10:05
I don't even know my own web address
Try www.lonards-automotives.com.au
FollowupID: 338293
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 10:10
Thanks Scott,
Mine is the TD42T. Another question you might be able to answer is on oil filters. From reading a number of sites it seems as though the 4.2 has had a number of filter changes in it's time. From using two of the same to two different filters. Plus different quality (I guess) as some cost approx $10 each and other $25 each, mine has two of the same at $25 each. What is the difference between the $10 and $25 ones?????
FollowupID: 338294
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 10:15
I can tell you for a fact that there's not much mate, did about 20 services on the Patrol. The filter brands are owned by the same company ie. Ryco and Repco.
I don't know much about failure rate, but I have used both filters and never noticed a difference.
I must admit though that Nissan don't charge much for their filters either and you would have a little more comeback at them if you used geniune. For air, oil and fuel, it was just as cheap to go to Nissan as it was to go to Supercheap or Repco...that is of course in Brisbane.
FollowupID: 338296
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 10:20
Hi Chris,
These are all genuine I'm talking about both the $10 and $25 ones. I even asked at the service section what the difference was and they thought it was just quality but didn't know.
FollowupID: 338300
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 10:24
Genuine Nissan?
Where was the cheap and expensive one?
FollowupID: 338303
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 10:34
Nissan supply 2 filters one a $10 one and the other is $25. They are both to suit the 4.2 turbo patrol, the cheaper one was used a couple of models ago and now they use the $25. But I can't find out what the difference is are they finer, etc etc.
FollowupID: 338305
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 11:03
Now I gotchya!
Last time I was in there, I was offered the cheaper as it is no different, only older.
Took the cheaper of course!
FollowupID: 338313
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 11:06
You would think there would have to be some difference. Bit unlikely that there is no difference but one is over 2 times dearer. Makes you wonder!
FollowupID: 338314
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 05, 2004 at 11:08
Well, I guess once production stops on the older type, we'll be stuffed! Just check with Nissan on my previous comments as that suited the GQ and it was a 90 model. If they say it's all good, save $30.00 everytime you do a change and spend it on the better oil!
FollowupID: 338316
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 11:12
I'll check next time I do a service. Certainly worth saving the money if the filters are adaquate.
FollowupID: 338319
Follow Up By: 80scruiser - Wednesday, Oct 06, 2004 at 12:51
OK
I use exactly what the book states. Better from a business point of view.
The early GQ's used 2 x Z115 filters and then in the GU they went to 2 x Z503 filters (using Ryco numbers which is a generally accepted part number accross most brands)
On the late model GU turbo diesel some run 2 x Z503 filters and some have 1 x Z503 and 1 x Z416. Most non turbo GU's run 2 x Z 503.
WHY - No body knows. Maybe Nissan found some old oil coolers laying around the warehouse and wanted to use them up.
In answer to your question whats the difference. Not sure. I have never looked into it or cut one in half to inspect the inside as I use exactly what the book says to use.
I will make a point of cutting some up next time to inspect the inside.
Stay tuned.
FollowupID: 338489
Reply By: sevo - Tuesday, Oct 05, 2004 at 11:26
gday guys,
i use the older style filter cheaper and no dramas
steve
AnswerID: 78904
Follow Up By: Austravel - Tuesday, Oct 05, 2004 at 14:52
Thanks Steve.
FollowupID: 338360
Reply By: Member -Dodger - Tuesday, Oct 05, 2004 at 17:17
My gu is a 2000 model and the filters are different. One is cheaper than the other.
I use after market filters and find them ok.
Cheers Dodg.
AnswerID: 78943
Reply By: Andrew - Wednesday, Oct 06, 2004 at 14:19
One is full flow and one is bypass type. You MUST use the ones specified for your vehicle as the threads are different.
Have a look at these archive threads on the Patrol4wd.org Forum for further info:
TD42T Oil Filters
TD42T Oil Filters2
AnswerID: 79078
