Wiring diagram for Jackaroo
Submitted: Wednesday, Oct 06, 2004 at 16:32
ThreadID: 16839 Views:5519 Replies:3 FollowUps:1
Does anyone have access to a wiring diagram for a 95 TD Jacharoo? I am interested in building a trip computer but need to know what the three wires coming out of the sender on the gearbox are.
Reply By: jackablue - Wednesday, Oct 06, 2004 at 17:14
Are the three wires comming out of the sender Black, Blue yellow, & Blue Green? then change to Black Green, Orange, & White on the transmission top kick panel. I think this is what it is on the petrol version. Maybe Savvas can confirm this. But it will only be petrol config he can confirm.
Hope this helps.
Jackablue
AnswerID: 79095
Reply By: Bobw - Thursday, Oct 07, 2004 at 08:16
Thanks for that can you tell me which wire is the actual signal wire which would go to the speedo?
AnswerID: 79172
Reply By: Trevor - Saturday, Oct 09, 2004 at 05:53
Bob,
I have an Isuzu workshop manual for '92 & '93 Jackaroos.
Although ours is a '97 petrol, I haven't found anything yet that isn't covered, except that the dashboard switches are different.
The circuits are the same, but the switches themselves are a rotary type, whereas ours are rockers.
Hopefully it covers your '95, but I can't be certain.
According to the book, for a '93 Diesel, the plug on the speed sensor on the gearbox has three wires connected to it.
Pin 1: +12v to the sensor from a switched fuse labelled "Meter gauge".
The wire colour is blue/yellow from the fusebox, but changes to yellow at the sensor plug.
Pin 2: Connected to earth.
The wire colour is black at the sensor plug, but changes to black/red at the earth point behind the RH mudguard.
Pin 3: Connected to the speedo.
The wire colour code is a bit hard to read.
It's either blue/green/white or light green/white.
The speed sensor transmits four pulses for each rev of the input shaft
There is a test procedure for the sensor.
You will need a 12v supply. A car battery will suffice.
1/ Unplug the sensor, and then remove it from the gearbox by unscrewing it.
2/ Connect + 12v to pin 1.
3/ Connect – 12v to pin 2.
4/ Connect a 1.3kΏ – 5kΏ ¼W or more resistor between pins 1 and 3.
Take care not to connect +12v to pin 3.
The sensor may be damaged if you do.
5/ Connect a voltmeter to pins 1 and 3.
6/ Slowly rotate the shaft of the sensor.
Each revolution of the shaft should cause the voltage to fluctuate four times between approx 10v and 14v.
There is a +/- 2v tolerance on these figures.
When you reinstall the sensor, it should be torqued to 27Nm.
I hope all of this is of some help.
Trev
AnswerID: 79450
Follow Up By: Bobw - Saturday, Oct 09, 2004 at 08:12
Thanks Trev,
That's exactly the info I need!
FollowupID: 338853
