Rust proofing what's the best
Submitted: Friday, Oct 08, 2004 at 09:24
Austravel
I intend doing my own rust proofing this time. Had endrust last time and no rust in over 13 years with plenty of beach driving. I'm thinking of fisholine but thought that there might be better products out there now. I'm going to do all panels, guards, underbody and chassis rails, the works. Any ideas on the best industrial product I can use with a spray gun and brush???
Reply By: MrBitchi - Friday, Oct 08, 2004 at 10:41
I,m thinking of doing the same and have found this product from Staun.
Masso 329
Does anyone know anything about it?
79353
Follow Up By: Austravel - Friday, Oct 08, 2004 at 11:21
Sounds good, but I've no idea. How is it applied??
338785
Follow Up By: MrBitchi - Friday, Oct 08, 2004 at 12:10
As far as I can tell you spray it on with a Masso Jet applicator, which means it's mixed with
water.
338789
Follow Up By: Austravel - Friday, Oct 08, 2004 at 12:28
That's what I thought as
well. I've tried a couple of
water based rust preventative detergants and they never worked for me. Stone chips still rusted etc. I guess you'd need to do a test on a couple of samples of metal over a couple of weeks or months. Please let me know if you find out it works.
338791
Reply By: jolls - Friday, Oct 08, 2004 at 11:05
I'm also looking at this for my new Hilux. What method are you intending to use for application? In my old hilux, 84 model, I used a spray gun with a fisholene equivalent, but it was messy. Worked a treat. I'd hate to do the same to my new one. what is the trick to application in the doors etc?
79354
Follow Up By: Austravel - Friday, Oct 08, 2004 at 11:12
I intend brushing some areas and buy a spray gun with an extended applicator. You can buy them with an attachment that fits up into the chassis rails.
338782
Reply By: Bundyman - Friday, Oct 08, 2004 at 13:53
I've used Lanotec which is a tacky oil produced from lanolin. It works very
well because it will seep into all the nooks and crannies and can be put on by brush or spray. The other advantage is that it doesn't have the horrid smell of fisholene. It does smell but no where near as bad. If you do use fisholene I'd recommend mixing it with 30% NEW (old oil is corrosive) engine oil to make it easier to apply and seep into cracks etc and also prevent it from going hard. Fisholene is also like a paint so any that gets on panel work will mark it. With either of these products you will still have to re-do your vehicle every 12 months or so depending on how often you pressure clean you 4by. A tar based product is best for under floor mats etc where it could stay wet for long periods of time. This is just my personal experience.
Hughesy
79369
Reply By: Bros - Friday, Oct 08, 2004 at 17:51
Austravel,
I used a mixture of Tectol and Fishoilene on my Tojo several years ago and appears to be working, as far as i can tell. Forgot the mix ratio, probably 1 Tectol x 2 Fish. Poke the extension up the channels and spray on way out.
Bros.
79389
Reply By: Bob H - Saturday, Oct 09, 2004 at 01:45
Hi there Austravel
Go the Lanotech way, you wont be sorry. check the old posts as there are some dealing with lanotech. great stuff.
79449
Reply By: Michael N - Saturday, Oct 09, 2004 at 08:27
I've heard of two different mixtures, both involving Lanotec. Either 70/30 Lanotec GP-21 and diesel or 50/50 Lanotec GP-21 and WD40. I used the diesel combination on my last ute but as ive only had it 3 years, cant comment on its true longevity. No rust yet though. I intend on using the Lanotec / WD40 mixture when i get my new truck. I also have an ERPS unit. No matter how long you spend treating the vehicle chemically, you will always miss a few small spots. This is where the ERPS units earn their keep. I used a 5L Pump Pack from Bunnings to treat the major components such as inside the panels and chassis rails. I then used a small syringe and cotton buds to treat around seals and the smaller components. I think it only took me about 1.5 litres of mixture to do the whole ute ( dual cab Triton styleside ) and a days effort. That included removing, cleaning and treating as many bolts and screws that i could find. I used Lanotec grease for that.
3 other bits of advice though. Do the rust proofing over LOTS of newspaper unless you have a work
shop. Also, make sure the vehicle is thoroughly dry and clean when you do it, especially inside the chassis rails ( i.e make sure they dont have 2 inches of mud set like concrete ). Lastly, and probably the most difficult thing .. give yourself at least a 2 weeks after treatment before you go off road and at least a month before you drive on sand. It will stick forever otherwise. Dust isnt so bad but sand is'nt exactly desirable. Infact .. if you can wait, double those times. I reackon it will be worth it.
Michael
79455
Reply By: Austravel - Monday, Oct 11, 2004 at 08:50
Thanks all.
79666
