Fishing rods in PVC pipe
Submitted: Monday, Oct 11, 2004 at 20:59
Gajm (VIC)
Anyone have any info or tips on carrying fishing rods, broken down, inside a bit of PVC pipe with the screw on ends on it?
I have one pipe I use to carry tent poles in, but I don't want to find out the hard way that the rods are going to get wrecked by being together.
It will be for 3, 6"6 rods, in a 90mm pipe thats 1100mm long
They have to be broken down because I don't have any more space on the car to attach another full length PVC holder. I know it will be a bit of a PITA each time we want to use them, but they are only going to be used occasionaly on trips.
Will they be ok, or do I need to line the pipe with rubber or similar, or do I need to cover each rod with a bag? or is it just a bad idea to transport rods this way?
Reply By: Richard - Monday, Oct 11, 2004 at 21:04
Carried them in a PVC pipe on outback trips but wrapped up inside in a soft plastic cover.
79800
Follow Up By: Gajm (VIC) - Monday, Oct 11, 2004 at 21:09
Thanks Richard, how many rods did you carry? and was it a store bought cover, or home made?
339178
Reply By: T-bone - Monday, Oct 11, 2004 at 21:08
My friends & I did 22000km (mostly offroad) around Oz last year carrying fishing rods in PVC pipe - we found the best solution was to wrap the entire rod in high density foam, and have it at a thickness so it only just fits in the pipe. As long as it's not too tight to bend the eyes on the rod, it'll stop any damage....
79801
Follow Up By: Gajm (VIC) - Monday, Oct 11, 2004 at 21:14
Thanks T-bone, that sounds like a simple enough solution.
I found a net today that folds up small enough to fit inside the pipe too, but I think it will be too much of a squeeze for rods, net and foam, so I'll just look after the rods.
339182
Reply By: Richard - Monday, Oct 11, 2004 at 21:14
carried three rods and the cover was a market umbrella cover
79807
Follow Up By: Gajm (VIC) - Monday, Oct 11, 2004 at 21:20
Thanks, I didn't want to have to lash out for one of those you beaut covers they sell for rods. Wife is starting to wake up to the fact my list of things needed for
camping never actualy ends.
339186
Reply By: Muddy 'doe (SA) - Monday, Oct 11, 2004 at 21:18
I regularly carry two or three rods on Airplanes in PVC Tube when heading north for Barra fishing. Just check out the oversize baggage claim at
cairns or
Darwin airports!
The best method is to wrap them in an cotton sheet (put one on the sheet and do a couple of wraps then another and a couple more wraps etc) and then put the whole wrapped package in the tube with some foam at each end before putting the end cap on.
You might need to experiment a couple of times with maybe one otr two sheets to get the right thickness package or the number of rods but this is the best method.
On the 4by you can just whack it on the roofrack and have confidence that your rods will be ready for fishing when you arrive at the secret spot!
Tight lines!
Muddy 'doe
79808
Follow Up By: Gajm (VIC) - Monday, Oct 11, 2004 at 21:27
Thanks Muddy, It's amazing how simple some solutions actualy are, I was thinking of gluing in old inner tube rubber, maybe seperating the rods between ply shelving inside the pvc...just slightly over working the problem.
Now to work out how to get info on peoples secret spots.
339189
Reply By: TD6 - Monday, Oct 11, 2004 at 21:57
Gajm,
Same as Muddy. Wrap a bed sheet around the rods. One rod two wraps then another rod and another etc etc If you are too short on diameter wrap another old sheet around the lot. Been doing this for years without a break (touch wood)
79817
Reply By: Jim-Bob - Monday, Oct 11, 2004 at 21:59
G'day Gajm
All you need to do is wrap your rods in plastic bubble wrap and slide them into your PVC pipe.
I have carried my rods up to
Cape York and throughout the Gulf (approx 25000klms) in two 6 week trips without a scratch.
Safe travells.
Jim-Bob.
79820
Follow Up By: Eric from Cape York Connections - Wednesday, Oct 13, 2004 at 06:56
Jim that seems a lot of ks in 6 weeks.
All the best
Eric
339345
Follow Up By: Jim-Bob - Wednesday, Oct 13, 2004 at 20:48
G'day Eric.
No Eric it's not, It was as read, two 6 week trips(12 weeks).
Safe travells.
Jim-Bob.
339475
Reply By: Des Lexic - Monday, Oct 11, 2004 at 22:52
I got the seamstress to sew up a bag for each rod from soft material and then put each rod into the pvc No problems.
79830
Follow Up By: flappan - Tuesday, Oct 12, 2004 at 09:14
Similar here.
Sewed up a calico bag for the rods. Tied them together with Shimano Rod ties (blue velcro strips) , and they slip into the PVC.
No probs to date.
339245
Reply By: A Digger - Tuesday, Oct 12, 2004 at 11:49
I have carried rods for many, many years in PVC tubes over some of the roughest roads in the country, as plane baggage and on numerous removals. Lengths have ranged from 13' one piece surf rods to barramundi rods with 2 or 3 rods per tube. The tubes are individually sized to match the lengths of the rods plus packing at each end and also the tube diameter to match the number of rods carried. On each tube, one end cap is glued on and not removable and the other end has a screw cap. After packing I wrap duct tape around the screw cap & tube.
I also wrap the rods in an old sheet(s) as described by others above but additionally I tie a piece of rag over each runner individually before wrapping in the sheet to stop any chance of rubbing. A bit of experimentation is required to get it right to ensure a snug fit. I also have a thick foam 'plug' at each end of the tube that prevents any sliding movement that could shock damage
the tip runner.
Never had a problem or the slightest damage. Tight lines.
Digger
79896
Reply By: Wok - Tuesday, Oct 12, 2004 at 13:02
Armaflex nitrile rubber tubing, UNSLIT......get from Clark Rubber, Bunnings, Lovelocks etc
Available in various id, just cut length to suit...rubberband at
the tip & 1 at the butt.
79907
Reply By: Member - Rohan K - Thursday, Oct 14, 2004 at 13:31
Gajm, the general concenus is that this is not a good way to transport rods. However, I do it and I carry 3 or 4 rods in a 100 mm tube. The real risk is that the rods will slide back and
forth and jump about and break guides. I broke a tip off one rod trying to get it out without removing all the rods :(
My experience is that 4 rods in 100 mm tube is 1 too many so 3 rods in a 90 mm tube may be pushing it too. Also, wrap or bag each rod separately and try to ensure they cannot move around at all.
80204
Reply By: geocacher (djcache) - Friday, Oct 15, 2004 at 00:55
Only one thing to say really.
Rod Socks
I put 3 small rods and a broken down 2 piece surf rod into 100mm tube. Oppose the ends so that not all the handles area at one end. I also drilled a hole through the screw on plumbing fitting cap and put a long coach bolt through from one side to the other. Then drilled the Coach Bolt "locking pin" to accept a small padlock.
Mounts to the side of the roof rack on stormy standoffs.
dj
80267
Reply By: Gajm (VIC) - Friday, Oct 15, 2004 at 10:17
Thanks to everyone who replied, I have plenty of ideas to try....also been trying to talk the missus into going North to try Barra fishing, but that's not an easy one to sell.
I like the sound of the Rodsox too, cheap enough and I think a much better way to store the rods all year, as my garage is like a bomb site. Thanks Dj for that link, and also for the coach bolt tip, I prefer my gear has a lock on it somewhere and that's not a bad way of doing it.
80284
