80 series constant 4wd
Submitted: Sunday, Oct 17, 2004 at 19:43
ThreadID: 17114 Views:2186 Replies:5 FollowUps:0
Could someone please tell me what is required to disable the constant 4wd from an 80 series so it can be towed behind a bus by an A-frame
Steve
"nothing ventured, nothing gained"
Reply By: theshadows - Sunday, Oct 17, 2004 at 20:06
Some on will correct me if I'm wrong so I'm wearing flame proof undies.
All four half shaft should be removed for flat "a" frame towing.
however on a couple occasions I have just dropped the front and rear tail shafts and let the diffs turn with out a problem.
I remember a freind with a Sierria that fitted lockable hubs to all his wheels and sweared by it. All he did was turn all hubs out and towed it everwhere.
shadow
AnswerID: 80570
Reply By: Member - Clive G (WA) - Sunday, Oct 17, 2004 at 22:40
Gday ,
I spoke to a chap once at a caravan park, he had a 100 series, we got talking about the front hubs, he told me he bought the car with constant 4wd, but had front lockable hubs put the front, he said too many workable parts on constant 4wd
Clive
AnswerID: 80616
Reply By: Moose - Monday, Oct 18, 2004 at 13:32
Check out the 80 Series COOL site - I think I recall reading about this issue on there in the past.
AnswerID: 80692
Reply By: Member - DOZER- Monday, Oct 18, 2004 at 20:06
You could simply put some AVM hubs on the front, and when unlocked, the vehicle could be towed (front wheels on the road). Lock them and you are back to constant 4wd. Drive with the transfer locked and front hubs unlocked, you will have rear wheel drive only, unlock the transfer and you have an undriveable cruiser.
AnswerID: 80763
Reply By: Penguin (NSW) - Tuesday, Oct 19, 2004 at 20:03
Can't you just put the transfer case into neutral or am I missing something?
AnswerID: 80927
