GQ Nissan Patrol
Submitted: Tuesday, Oct 19, 2004 at 08:58
ThreadID: 17153 Views:3062 Replies:3 FollowUps:6
Hi All, first time to ExplorOZ. You have probably had this before but am looking at buying an older diesel GQ Patrol, around 1988 - 2001. What sort of things to be aware of. I have had Range Rovers all my life so venturing into Nissan territory is a bold step. I hear that the diffs are strong as houses but need info on stuff like electrics and overall reliability. Is any particular model better than another one?
Thanks in advance.
Reply By: Truckster (Vic) - Tuesday, Oct 19, 2004 at 09:08
www.gqpatrol.com and look on the left frame theres a page called Buying a GQ?
Steer clear of 2.8 - gutless, 3.0, thirsty.. TD42 is the pick of the crowd.
What do you want to do with it?
AnswerID: 80811
Follow Up By: Joff - Tuesday, Oct 19, 2004 at 14:48
I live up in Tom Price (north western, WA) and it gets VERY hot up here so it being able to cope with very high temps is important. Also very long drives between petrol stations so range is also important. Other than that just general reliability. Like the back space in the Patrol as we usually fill the back up with camping gear.
Joff
FollowupID: 340124
Follow Up By: Truckster (Vic) - Wednesday, Oct 20, 2004 at 12:03
For what you are saying I would suggest the TD42 without fail. Since distance is a must, you wont beat it with anyother of the GQ motors.
Overheating has been mentioned with some GQs when an aftermarket turbo is added. In the end I went to the people who make it to get it sorted out, the did it within an hour, where other places took days. Mine happily sits on 1/4 up the Hume 30degree day(few weeks ago).
Same as any motor they will last years without fail if treated well, with numerous having over 500,000-600,000klms and still going - Denco Diesel have one with over 900,000klms on it which is their test truck for turbos. They told me its still OEM donk.
Again check my page for a list of things to go thru when buying one.
FollowupID: 340257
Reply By: Member - Chris M (QLD) - Tuesday, Oct 19, 2004 at 10:02
The GQ went from 1988-1998 mid.
Venturing from Range Rovers to Nissan is a good step.
The whole truck is the way to go, their tuff as nails. If you are looking for diesel, then you'll be picking up a 5 speed TD42.
Lotsa goodies available, rust in rear window frames, but replaceable. If they are a comp truck, cracks around battery tray. Look for dints, scuffs, scratches in underbody, diff casing and trailing arms.
Electrics, the clock never works, toss that and you can put a gauge of your choice there with a little plastic trimming. With big k's comes fuel pump rebuild if flat spot, injectors maybe and water pump.
For a 200,000 k TD42 with turbo and goodies can fetch up to 18k. If body a bit rough, may go as low as 12k.
If you buy naturally aspirated and not aftermarket turbo, and have 7k left over, get snorkel, suspension, tyres, and aftermarket turbo with exhaust and injectors, you may even squeeze in fuel pump rebuild if you really push the guy. A good 3 inch suspension kit will cost around $800, turbo $4-5k, snorkel coupla hundred if you fit, and tyres, well the sky's the limit. You will then have a truck that's pretty much trip/play ready.
Hope this helps.
Chris.
AnswerID: 80821
Follow Up By: Ian from Thermoguard Instruments - Tuesday, Oct 19, 2004 at 10:26
"Venturing from Range Rovers to Nissan is a good step." Wash your mouth out with soap, Chris!
Rovers rule, OK!
FollowupID: 340067
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 19, 2004 at 10:33
Own a Rangy as well mate.
Spending way too much at the moment. I must admit, first time I've made a bad vehicle decision! Pulled down motor, pistons, rings stuffed!
Trying to source second hand rangy for parts at the moment.
But admitedly, good car, but Nissans are better. ;-)
FollowupID: 340068
Follow Up By: Ian from Thermoguard Instruments - Tuesday, Oct 19, 2004 at 10:55
You're forgiven, Chris. Hope you get the Rangie fixed without too much hassle. If you do, then sell it quick, before it gets under your skin and you become 'infected' like the rest of us poor demented Rover lovers!
FollowupID: 340071
Follow Up By: Member - Chris M (QLD) - Tuesday, Oct 19, 2004 at 12:09
Gday mate,
Thanks mate.
Need a hobby and it's better than smoking mate. Part demented anyway!
Nissan, Tojo's, Rangies, they all give us a headache at some stage!
Cheers mate,
Chris.
FollowupID: 340086
Reply By: Mark- Wednesday, Oct 20, 2004 at 21:05
You wont regret making the change. You'll never worry about breaking diffs/axles again and stupid electrical problems will also be a thing of the past. I've had Rangies as well and understand their appeal but the Nissan is way better from a reliablity/strength/longevity point of view. (The clock is easily fixed, just need to resolder one of the resistors on the back. You can work out which one it is by touching them while the power is connected to the clock. The clock will come alive when you press on the right resistor. Basically remelt the solder joint with a soldering iron and its fixed. You dont even need to know how to solder)
As others said previosly, the TD42 is the way to go. Mine has 485000km on it and isnt even beginning to look like its tired. Theres still no oil leaks anywhere (apart from the steering box) I bet your rangie has more leaks than that! The gearboxes are also way over- engineered - this one doesnt make any noises and has no clunks. Its towed a tandem caravan for about half of its life. I'm not trying to start an argument here but every Toyota 5 speed I've seen is noisy in at least 5th gear and is starting to get tired syncros by about 250-300000km. The standard Nissan limited slip rear diff in mine is still tight after 485000 (tyres still chirp slightly on a U turn) The bodies can and do get a bit tired, eg cracks can develop in a few places like base of firewall, inner guards, rear door tops and theres always a few or more rattles but they wont fall apart.
AnswerID: 81046
