Cable Beach Broome Access - max tide
Submitted: Tuesday, Aug 13, 2002 at 00:00
Garry
Hi does anyone know what the maximum tide is for access onto the northern section of
Cable Beach in
Broome is? That is without taking the Cruiser for a swim. Trying to plan a holiday and want to maximise the timing for access to and from
the beach. I know it is mid to low tide, but was wondering if anybody knew the tide hight in meters, ie 4.5m etc.
Ta'
Reply By: Willie - Wednesday, Aug 14, 2002 at 00:00
G'day, Tide height in
Broome can be up to 11 metres. If
Cable Beach is still accessible(haven't been there for a while), then you can access it at low tide and drive all the way up to
Willie Creek(no relation of
mine). Best to stay close to the dunes and find a hard track to follow along. Cheers, Willie
5678
Reply By: Garry - Wednesday, Aug 14, 2002 at 00:00
Thanks Willie. I've already been to
broome several times and driven on
Cable beach. Just can't remember the maximum tide the you can still drive past the rocks on to access the northern section. I have a feeling once it gets past 4.5m or so the
water is too high.
5682
Reply By: Allyn - Wednesday, Aug 14, 2002 at 00:00
Plan around the neaps and you won't have any fear of being blocked in
5683
Reply By: Garry - Thursday, Aug 15, 2002 at 00:00
Contacted
Broome Ranger. Apparently if you work on 6.8m as being the maximum passable tide you will be ok. That means anything below 6.8 and you should be able to get around the rocks to access north
cable beach.
5735
Follow Up By: Allyn - Thursday, Aug 15, 2002 at 00:00
That is surprising as I would have thought 6.8 metres to be way too high to get through the rocks without getting your fourby wet. You learn something every day in this
forum. Thanks for the info
2486
Reply By: Garry - Friday, Aug 16, 2002 at 00:00
I think it really depends on the sand movement at the time. Sometimes the track through the rocks is quite close to the dunes, other times it is around 50m out and winds back.
Hopefully the
ranger wasn't just giving me a red herring!
5767
