rollout awning
Submitted: Thursday, Oct 21, 2004 at 23:56
ThreadID: 17216 Views:2005 Replies:2 FollowUps:0
help! instructions needed to roll up the awning. This is all new to us, and as there were no instruction manuals supplied (2nd hand) could someone please explain fairly simply the procedure to roll the awning up. The 'arm' has the tightening nut, the leg has the pull out lever to adjust the height. Which one is put down first before the awning is rolled up? Any help would be greatly appreciated! Thanks.
Reply By: harry5 - Friday, Oct 22, 2004 at 03:27
Tylah to roll it up.
Undo the arm nut lift the lever on the leg you probarly need to try and raise it a touch then it should slide back, I do one leg partially then go to the other leg same thing until you get them fully inThere should be a button at the end of each leg
which releases the arm push the arm right in,It should slide along the leg. Then grab the tape( which you use to control the rewinding awning) ,Turn The dial to wind up and travel and let the awning roll up Tighten your arm nuts again and secure the legs for travel
AnswerID: 81178
Reply By: GOB & denny vic member - Friday, Oct 22, 2004 at 17:38
tylah
why dont you go to a caravan place and get them to demonstrae for you it is very hard to explain
steve
AnswerID: 81261
