6volt
Submitted: Saturday, Oct 23, 2004 at 17:28
ThreadID: 17246 Views:2030 Replies:3 FollowUps:3
Dont laugh at question. A 12volt deep-cycle batt is fully charged at 12.80 and
flat around 12.20. what are the figures for a 6volt deep-cycle ( 6.40 and 6? )
cheers brian
Reply By: Mike Harding - Saturday, Oct 23, 2004 at 17:57
Terminal voltage is not a very good indicator of the state of charge of a lead acid battery but if you're sure the battery is in good condition it will give you a fighting chance of estimating the charge level.
12V5+ is around the right number for a fully charged battery but it will discharge to much lower than 12V2 - I'm not sure what the bottom figure for a deep discharge battery is (if you find out please let me know) but a normal cranking type battery can go down to 10V5 before it's in danger of suffering damage.
6 volt batteries will be half the above figures at they comprise 3 cells whereas 12V batteries comprise 6 cells.
Mike Harding
mike_harding@fastmail.fm
AnswerID: 81347
Follow Up By: V8troopie - Sunday, Oct 24, 2004 at 01:15
Mike, let me qualify your statement about a cranking battery suffering no damage if discharged down to 10.5V.
This only holds true IF the battery is IMMEDIATELY re-charged.
If you were to leave a discharged battery for some days you would find that the plates have sulphated and this did indeed damage it.
Klaus
FollowupID: 340621
Follow Up By: Mike Harding - Sunday, Oct 24, 2004 at 06:47
Sulfation is a slow chemical process so don't worry too much about IMMEDIATELY recharging the battery. I wouldn't try and put a precise time limit on it but you could certainly leave the battery in a discharged state for a day or two without significant sulfates building up. However the thrust of what you say is quite correct and even a fully charged battery should be "topped up" every month or so if it's in storage - makes you wonder about batteries sitting on the shelf in a dealers for months on end?
Also high temperature is bad for batteries so maybe store them in a cool spot in the house rather than in a garage if your garage gets hot in summer.
A good site for all things battery:
http://www.uuhome.de/william.darden/
Mike Harding
FollowupID: 340625
Reply By: Penguin (NSW) - Saturday, Oct 23, 2004 at 18:58
eis a pretty comprehensive deep cycle battery FAQ.
AnswerID: 81350
Reply By: Penguin (NSW) - Saturday, Oct 23, 2004 at 19:00
Oops Try again.
Here it is
AnswerID: 81351
Follow Up By: Member - Brian (WA) - Saturday, Oct 23, 2004 at 21:47
Thanks Penguin
Good site
brian
FollowupID: 340596
