ARRID Twincharge
Submitted: Sunday, Oct 24, 2004 at 06:04
ThreadID: 17259 Views:9970 Replies:11 FollowUps:10
Has anyone used the ARRID Twincharge? I need feedback on this unit please.
Rgds
Reply By: Eric from Cape York Connections - Sunday, Oct 24, 2004 at 13:54
Wok It may sound dumb but what is it.
All the best
Eric
AnswerID: 81431
Follow Up By: Wok - Sunday, Oct 24, 2004 at 15:46
Sorry, should have linked!
ARRID
FollowupID: 340661
Reply By: Eric from Cape York Connections - Sunday, Oct 24, 2004 at 16:20
No sorry I cant help you.
All the best
Eric
AnswerID: 81442
Reply By: Penguin (NSW) - Sunday, Oct 24, 2004 at 17:28
Hi Wok,
I know of at least one forum member who uses and swears by his. He uses it to charge his camper trailer battery.
It's a 20A device whereby the input voltage is not critical (down to about 10-11V) as it increases the output voltage to 14+V.
I have a similar thing on my trailer but it's a 10A charger from Engel. No complaints whetever.
AnswerID: 81448
Reply By: Baz (NSW) - Monday, Oct 25, 2004 at 08:21
Wok, Mike would be talking about me we have one it's brilliant so far does what it is supposed to and does it well we have our second battery in the camper next to the Arrid charger connected to the main battery via an anderson plug on the tow bar to the ignition so it is only on when the car is going, as Mike has said it pushes a large amount of amps first of to allow for any voltage drop because of the distance from main batt to the second batt in the camper it is designed for this purpose, (ie) campers, caravans and they are very good value for money as well i would reccomend them and anyone else who has one would too, ring the guy at All About 12Volt in Sydney or the 12volt shop in WA.
Baz.
AnswerID: 81500
Reply By: Wok - Monday, Oct 25, 2004 at 09:19
Thank you all........looks like I will be saving some $ for a while...should be a good longterm investment.
rgds
ps : Found a useful site
Baintech
AnswerID: 81508
Reply By: Member - Collyn R (WA) - Monday, Oct 25, 2004 at 11:01
The Arrid Twin Charge device is technically a dc-dc converter.
It is a box that sits next to the trailer battery and converts whatever (within reason) is coming down the line - to 14.4 volts.
It is effective in that it overcomes the voltage drop that is otherwise inevitable unless the system uses adequately heavy cable. Do note though that the device cannot and will not counteract problems such as corrosion in trailer connectors, poor earths etc.
Further, as it requires well over 14.4 volts to fully charge a conventional lead acid battery, this device is thus still limited to charging a trailer-situated battery to about 70% or so. But this may of course be twice what you had before!.
A very effective alternative is to use a gel cell battery in the trailer. These charge speedily and to close 100% charge from as little as 13.8 volts, and very effectively indeed from 14.0-14.1 volts. They are damaged by voltage over 14.4 volts - but there's diddly-squat chance of that from the end of several metres of trailer wiring.
With respect to Arrid, I personally feel the gel cell battery is a better approach as you will be able to access almost all the amp/hours you paid for - and at not that much higher cost than the Arrid device. But that is not intended as a put down on the latter.
Collyn Rivers
AnswerID: 81532
Follow Up By: Penguin (NSW) - Monday, Oct 25, 2004 at 12:26
Collyn
I seem to remember that my Engel charger puts out about 14.8V and I have a GelTech battery in the camper.
Given your statement that they can be damaged by charging at over 14.4V, would it be worthwhile putting in a solar regulator to protect the battery and also to be prepared for solar (after I rob the bank)?
FollowupID: 340753
Follow Up By: Wok - Monday, Oct 25, 2004 at 12:38
Hello Collyn,
Thks for that, I had a chat with ARRID awhile ago and I was led to believe that the Twincharge is a dc-dc converter followed by a 3-stage charger?...for this reason they had to 'set the unit' to match the battery.ie it is not a universal device. Have I misunderstood about the operation of the ARRID?
Why do you favour the Gel-cell over the AGM type of battery? I don't expect to use solar-panels...just don't have the room.
Rgds
FollowupID: 340754
Reply By: Member - Collyn R (WA) - Monday, Oct 25, 2004 at 12:36
Penguin
I'm always for adding solar!
What you can do is this:
Any good solar regulator has a program specifically for gel cell batteries - so that fixes the first issue.
A solar regulator does not know the difference between a solar module and a battery charger (and does care either) so you can feed the input from the charger through the solar regulator and thus use it as a smart charger.
Regulator makers rarely spell this out in as many words, but some (such as Plasmatronics) state that the regulator will accept suitable dc input from a range of sources.
Good solution.
Trust this helps
Collyn Rivers
AnswerID: 81548
Follow Up By: Wok - Monday, Oct 25, 2004 at 12:42
HIP HIP HIP HOORAY!!!!!
Collyn, you have just solved my problem.......so what brand/type of solar-regulator do you suggest ?
rgds
FollowupID: 340756
Reply By: Member - Collyn R (WA) - Monday, Oct 25, 2004 at 12:46
Re gel cell and AGM.
Personally still prefer gel cell as am concerned about ongoing reports of premature failure in AGMs in hot areas - such as up here where we live (north of Broome). Whilst reports are anecdotal there seem to be a fair number of them.
I'd prefer to wait for a bit before unconditionally recommending AGMs for use in hot places.
Will recheck re Arrid Twin Charge but my understanding is that the output is that of a typical constant voltage charger.
Collyn Rivers
AnswerID: 81550
Reply By: Member - Collyn R (WA) - Monday, Oct 25, 2004 at 13:09
Wok
Recommend Plasmatronics PL 20 (up to 20 amps) or PL 40 (up to 40 amps).
I like them as they are so versatile and have every monitoring facility that you will ever need.
Make absolutely sure you follow the makers wiring instructions to the letter. Many are wrongly installed even by professionals.
MUST be wired solar plus to battery plus - and a second light lead from battery plus BACK to the regulator Batt +.
Many people try to outguess the maker and wire it solar plus to regulator Batt + and then to battery plus. This results in the regulator getting wrong info and cutting back the charge.
Trust this helps
Collyn Rivers
AnswerID: 81554
Follow Up By: Wok - Monday, Oct 25, 2004 at 16:46
Hello Collyn,
Very fruitfull afternoon...visited Plasmatronics & your site [excellent]
1. I gather that the PL20 is a shunt regulator?
2. I couldn't find any direct referance to input voltage range for the unit. My plan is to run from the alternator to the PL20.......feasible?[only 14.1V available]
3. You mentioned a 'smart alternator' that is fitted to your OKA, would this be the AMPLE unit?
Quietly......are you THE CR from EA [alas poor Yorick]
rgds
FollowupID: 340804
Reply By: Member - Collyn R (WA) - Monday, Oct 25, 2004 at 18:38
Wok
PL regs are series regulators and switch the negative line via pulse width modulation. Shunt regs are used nowadays mostly with wind generators.
Input voltage is settable at 12, 24 and 48 volts.
Smart regulator on the OKA is a TWC unit that was sold for a time by Hella. Adverc make a vaguely similar unit - there's a link to them via my website.
More or less Yes to the last query - but my magazine was ETI (I founded it in 1971).
Collyn Rivers
AnswerID: 81604
Follow Up By: Wok - Monday, Oct 25, 2004 at 19:48
Collyn,
My apologies about the mag......I gave up when SMDs came in...toooooo small!
The ADVERC OSCA=1212 looks like what I expected the ARRID unit to be..with the 3 stage charger.
The PL20 is big enough for my needs and the low voltage cutout is a bonus!
Thanks again....one day we may crack a coconut up your way..
rgds
FollowupID: 340814
Reply By: Member -Dodger - Monday, Oct 25, 2004 at 22:28
Wok,
I have had two vans in which I have installed Arid twin charge systems and it worked a treat in both. I have found that approx 4hrs running is required to bring a low battery up to scratch.
Yes I agree with Collyn that solar power is the way to go however there are times when old sol just does not show his face enough.
Cheers Dodg.
AnswerID: 81662
Follow Up By: Wok - Tuesday, Oct 26, 2004 at 05:37
Dodger,
What battery do you use with the ARRID?
I think solar is viable for tropical longtitudes & 'good green feeling' but cold logic ends up with puresinewave generator[ ultimately, such a genie with inbuilt 3 stage charger will appear]
Collyn brought up a good point about temp & AGM...looking at the Fullriver site the upper temp seems to be 50c.
rgds
FollowupID: 340864
Follow Up By: Member -Dodger - Tuesday, Oct 26, 2004 at 08:58
Wok,
First van had a normal lead acid nz70 deep cycle. (was still going strong when van sold after 5 years.)
The van I now have has a sealed deep cycle lead acid battery which is now 3 years old and still going strong.
I must add that I have also installed a charge & maintain 240v charger of 1.6amps rms that charges when the van is connected to the mains.
This unit has pulse teck that pulses the batt when fully charged.
With the 64watt unisolar panel the system is able to run the van for unlimited days camped provided that the sun comes out.
Note the van has been round the block twice and has even survived 52 deg cels for one week however we suffered a lot.
Cheers Dodg.
FollowupID: 340880
Follow Up By: Wok - Tuesday, Oct 26, 2004 at 12:20
Dodger,
Thks, I need a sealed unit as the aux has to be in the cabin. It looks like the ARRID works [at least there have been no failures reported!]
rgds
FollowupID: 340910
Follow Up By: Member -Dodger - Tuesday, Oct 26, 2004 at 17:41
Wok,
Best advice I can give now is to ring Arid in WA and talk to them as I have found them most helpfull and they mail order gear anywhere.
ph 08 9458 1212.Fax 08 9458 1977. Or Sydney 02 974 81199
sales@12volt.com.au
Web site www.12volt.com.au
Yes I have dealt with them a no of years & can recomend them
Cheers Dodg.
FollowupID: 340955
