Jackaroo TD water pump
Submitted: Monday, Oct 25, 2004 at 10:22
Will
Hi Guys calling Jack owners, has any one replaced their
water pump on a diesel Jack, (4JX1) motor (7/99).
Mine looks to have a weep, and when I equired about a replacement found out there is not an after market one available and have to buy genuine @ $402.00 retail. Thats when I had a weep.
Any one know of a after market one.
Will
Reply By: Leroy - Monday, Oct 25, 2004 at 12:26
I can understand your weeping Will.....Maybe worth looking at buying one from the USA could be a cheaper option. Never done this but they have heaps more Isuzus than us here so maybe better prices as
Leroy
81544
Reply By: Banjo (SA) - Monday, Oct 25, 2004 at 13:08
Yep - Isuzu Trooper in the US - bit of surfing might be the go - I've ordered a polyair type
suspension bag kit from there - hope it turns out ok - will post when done.
81553
Follow Up By: Member - Jeff M (WA) - Monday, Oct 25, 2004 at 14:25
I've got the firestone's on order too! :-)
Should arrive sometime this week, will also let you know how it goes.
340771
Reply By: Rick Blaine - Monday, Oct 25, 2004 at 18:41
Try Jackeroo world....usually have "genuine" parts a lot cheaper or if you have a mechanic mate see if he will buy you one at trade about $130.....
http://jackworld.alphalink.com.au/
81606
Reply By: Andrew from TrekTable - Monday, Oct 25, 2004 at 20:46
Will,
Thanks for the post. I changed my oil & filter on Sunday & noticed a slight weep from the
water pump. Will check it out in more detail now. $400 is abit steep.
Seperately, does anyone know of an alternate oil filter supplier? I've been $48-52 dollars over the years and can only get genuine from Holden. Any other sources? Same motor (4JX1).
81626
Follow Up By: Will - Monday, Oct 25, 2004 at 22:56
Hi Andrew,
I use a oil filter from my local Peps auto store in Engadine, the number is WZ 600, I believe it is made or marketed by Wesfil @ around $20 to $22.
Will
340855
Reply By: ColNT - Tuesday, Oct 26, 2004 at 08:54
Will ,
Water leaking from near
water pump can be coming from block to head transfer pipe seal at head end of pipe,gets very hard . I had to replace
mine not long ago.
Col.
81691
Follow Up By: 1 Mark - Tuesday, Oct 26, 2004 at 17:06
Col
just curious did you end up getting the head fixed on your Jack?
340947
Reply By: ColNT - Wednesday, Oct 27, 2004 at 10:35
1 Mark
Yes the head is fixed it was the intake valves leaking due to pitting on the valve face .The head rebuilder said it is not an uncommon with engines that have exhaust gas running back in the intake.
Having Fun Colin
81877
