Tyre Size: 265/75 or 285/75
Submitted: Monday, Oct 25, 2004 at 10:42
Member - Alan S (NSW)
Just about to buy some tyres for the 4x4. I have new
wheels but have still to decide on what tyres to go for. The obvious choice is 265/75/16 as these will match the same diameter to what is already there so no change in speedo readings (7.5R16).
The guy at the tyre
shop said I should also consider 285/75/16 as a lot of his customers choose this tyre size.
But why? What advantage do 285's have over 265's? Please help here, any and all opinions greatly appreciated.
BTW price is not that different so that's not a valid reason. Thanks.
Reply By: Leroy - Monday, Oct 25, 2004 at 10:52
Alan,
I actually specified 285*75 when I bought my vehicle. The reason I got this size is because I got a little bit more air between the ground and the diff. Also most of my mates have this size so if i need to use thier spare I can and they look better ;-)
Leroy
81529
Follow Up By: Member - Alan S (NSW) - Monday, Oct 25, 2004 at 11:08
Thanks Leroy,
Most of my mates drive sedans so I won't get the benifit that you have with 285's! They might look better alright.
Now I am wondering how much difference the larger tyres will make to power with my non turbo 4.2 diesel...
340744
Follow Up By: Leroy - Monday, Oct 25, 2004 at 11:57
Can't answer what difference it may make to the power of your vehicle as I have a 3.0l Patrol but my beast copes fine. Also I don't think you will have a prob with tyres rubbing etc from what I have seen.
Leroy
340749
Reply By: Member - Chris M (QLD) - Monday, Oct 25, 2004 at 10:56
Will suck more power, depending on your state, probably won't be legal, only 15mm allowed in size.
If you don't run a
suspension lift, may rub at full compression, don't quote me on that one, just hazzarding a guess.
Won't be that much more clearance.
81531
Follow Up By: Member - Alan S (NSW) - Monday, Oct 25, 2004 at 11:06
Hi Chris,
The new tyre placard states 275/70 so it'll be legal no matter which size tyre I choose. I hadn't thought about rubbing. I'd like to hear from others about that one. The
suspension upgrade won't be for a few months yet. Thanks. Alan.
340742
Follow Up By: Member - Chris M (QLD) - Monday, Oct 25, 2004 at 11:12
Good stuff...good to know whether they will rub or not...
340745
Reply By: Member - Captain (WA) - Monday, Oct 25, 2004 at 11:29
Hi Alan,
On my previous 1HZ 80 series, i originally had 31x10.5xR15 (~265/75R16) that I changed to 33x10.5xR15 (~285/75R16).
I never noticed any major difference on road (gearing changed ~7%) but offroad was a world of improvement. On a particular beach track I previously had to lower pressures to ~20psi whereas the 33" could do it at the road pressure of 45psi. And once the 33" were lowered, it was virtually unstoppable on sand, something the diesel 80 previously didn't relish.
It was something I wished I had changed much earlier, I always knew that the bigger tyres should be better off-road, but didn't resalise by just how much. There is basically little difference between the standard 80 and 100 series and I would expect a similair level of improvement from your 100 series.
When I picked up my new GU from the dealer, the very first stop was the tyre
shop where I replaced the standard 265/70 with 285/75, thats how convinced I am that 285/75s are the way to go!
Captain
81535
Follow Up By: Brent.n - Monday, Oct 25, 2004 at 21:18
Captain did you do any
suspension mods, do the tires rub, i have a GU as
well and was wanting to do the same.
340832
Follow Up By: Member - Captain (WA) - Monday, Oct 25, 2004 at 21:32
Hi Brent,
The front tyres do not rub at all, but the back just kiss the top inner guard on full articulation with standard
suspension. Not a problem IMHO.
Captain
340841
Reply By: AT4WD ADVENTURES - Monday, Oct 25, 2004 at 12:58
Alan,
I have always run 285/75/r16 on my 100 series and for the bulk of the reasons above. Bigger footprint, more float etc particluarly when running lower presssures. I run BFGs A/Ts and have received around 70k out of the first set on this vehicle and love the tread pattern. I also welcome the extra diff clearance provided, the gearing change is minor although I notice it most on very long steep declines and the speedo is also out which I have gotten use to.
I have a moderate
suspension lift and have no problems with tyres rubbing. Good way to go in my opinion.
Stuart.
81551
Reply By: Moose - Monday, Oct 25, 2004 at 13:38
In theory the wider tyre should last longer - same weight spread over more rubber should equal better wear rate.
81560
Reply By: Member - Alan S (NSW) - Monday, Oct 25, 2004 at 14:58
Looks like I am leaning towards 285's. I just hope that there is no rubbing. I'm sure they will do fine until I can afford the
suspension upgrade, thanks all for your responses and if anyone else has any opinions please don't be shy....
81577
Reply By: basecamp15 - Monday, Oct 25, 2004 at 21:06
I'd say you'll have to get wider rims too for either of these tyres. If the rims are 7 inch, which I doubt, you will be able to fit the 265's. Something to consider.
Cheers, Mark.
81640
Follow Up By: Member - Alan S (NSW) - Monday, Oct 25, 2004 at 21:50
Hi Mark,
I have new rims ready to put on the LC. I have been to hell and back trying to get these rims approved and ended up getting the RTA here in NSW to talk to Toyota Australia to get the mod approved without an Engineers Cert. Now that I have that sorted I am not thinking about the tyres. Thanks, Alan.
340851
Reply By: Crackles - Monday, Oct 25, 2004 at 21:58
Alan. On a 4.2 HZJ105 the 285's do suck a fair bit of power on the road & you will notice the car will be a little sluggish at passing speeds & when climbing hills. Offroad they are great and in the lower gears you will barely notice the size difference. That extra little bit of clearance does however make a heap of difference in the rough stuff. They do fit in the wheel arches without touching.
I run the 285's as a second set for the bush but if the majority of your driving is on the blacktop I'd stick with the 265's.
Cheers Craig............
HZJ105 RV
81657
Follow Up By: Member - Alan S (NSW) - Tuesday, Oct 26, 2004 at 13:05
Thanks for that Craig,
I am not sure I want to loose any more power on the open road as its already sluggish enough and a turbo is not on the cards for a while, if ever! I will only be able to afford to run one set of
wheels and tyres too.
I live in
Sydney and we are moving to
Perth so other than fun weekends 4x4ing most of the driving will be on black top.
I'm no closer to a decision now than when I started but thanks for all the responses.
340915
