Moreton Island
Submitted: Tuesday, Oct 26, 2004 at 10:34
Member - John C (QLD)
Thinking of 2 wks at
Moreton Island for Xmas. Never been.
Want to take camper trailer. Is this reasonably easy?
Been on sand plenty - without trailer. Always run pressures around 18psi.
Would do so on trailer also, obviously.
Also any suggestions on where to
bush camp with the trailer and somewhat away from the crowds.
Thks, any help greatly apprec'd.
John C
Reply By: RussellV - Tuesday, Oct 26, 2004 at 11:01
Hi John
I would avoid taking a trailer over if possible (they also sting you on the barge for it as
well). There are a few spots on the island that will take a trailer, however you'd need to roam around to work out which is more away from the crowds. Let's face it Christmas on Moreton you are bound to expect crowds wherever you go. I prefer the
ocean beach camping to the western beach and I know Eagers
Creek has flat grassy area suitable for camper trailers. The
camp site at
Blue Lagoon would also be suitable. Also on the western beach southern end there is some good
camping under the trees below the big sand hills south of Tanga. Hope this helps.
Russ
81707
Reply By: MrBitchi - Tuesday, Oct 26, 2004 at 12:10
"somewhat away from the crowds" Over Xmas? Ferget it!
You'll have no probs with the trailer but any of the islands are as busy as ..... over Xmas.
81722
Reply By: Member - Crazie (VIC) - Tuesday, Oct 26, 2004 at 14:35
Hey John
Moreton, great place, but xmas will be busy busy.
Blue lagoon or around the wreck would be a good spot, I think russel mentioned these as
I wanted to raise the question as to why you would drop the tyre pressure on the trailer. We always pull boats up
the beach around bribie, morton and fraser and have always found it better when the trailers maintained normal pressure. If you lower the pressure in the trailer you are then pulling it through the sand rather than on top. Just my opinion , not to be a smart arrse.
Adam
81736
Follow Up By: Member - John C (QLD) - Tuesday, Oct 26, 2004 at 15:12
I have read somewhere to do it when towing a heavy camper trailer (1100kgs). If you have to stop in soft sand for one reason or another it can become a dead weight, better not too risk it and deflate.
But it makes more sense what your saying.
Also have been told to turn trailer brakes off altogether, at wrong setting they can risk pulling car up and digging trailer in and becoming an anchor.
340935
Follow Up By: Member - Crazie (VIC) - Tuesday, Oct 26, 2004 at 15:21
Always a few differnet opinions, what ever works John, Luckily the boat is no where near those kgs.
Have a great trip, Take the rods, play with the dart.
Great looking camper trailer.
Ad
340937
Reply By: Graham- Tuesday, Oct 26, 2004 at 18:13
Hi John,
My family and I have been ther only once, and at Xmas. Yes it can be a bit crowded depending where you go.
We went south of Tangalooma. The bypass road around Tangalooma is soft sand and you would need to be pretty adept at trailor towing in sand to do it but we saw heaps of trailers when we were there.
From 2-6... and more klms south of Tangalooma there are quite a few spots you can
camp on the "above high tide" areas.
We found a great spot nestled in amongst the trees and backing onto the large dune that bounds that southern stretch.
Just remember that you can only drive
the beach on the western side at low tide times and it is easy to get caught away from
camp. We nearly didn't make it back on one drive out. ((Tide chart is a must!!)
I assume you have kids so I would suggest that you got the Western side for the safe swimming and dolphins.
Water is pretty shallow and safe area for kids.
Mind you - the vehiclkes driving
the beach have to be kept an eye on but all in all we found that most people did slow down or showed they were watching.
There are no
toilet facilities in that stretch so you need to dig a dunny and you also need your own supply of fresh
water.
A drive up to Tangalooma for a swim and fresh-
water shower ((the day trippers use them as
well)) can be nice :-)
Graham
81756
