Twine Hot water Unit into Landcruiser 105
Submitted: Monday, Nov 01, 2004 at 15:20
ThreadID: 17473 Views:3608 Replies:4 FollowUps:6
Can anyone tell me which heater hose goes to the tap in the 105 landcruiser? Top or Bottom as they go through the firewall? Will save me pulling half the dash apart to find out as the tap is inside. Have thought about putting in a couple of T's and an aftermarket tap to control the temp if I have to.
Mick
Reply By: AT4WD ADVENTURES - Monday, Nov 01, 2004 at 16:48
Mick,
Where are you located? I am in Sydney and if you want you can have a look at my setup, otherwise I will grab a pic of the install and email to you.
Regards,
Stuart.
AnswerID: 82566
Follow Up By: AT4WD ADVENTURES - Monday, Nov 01, 2004 at 16:52
Mick,
I should also add I have a mixer tap that I added on the shower side of the heat exchanger ciruit to mix hot with cold as you would in a normal shower and find it far more accurate than mixing from the dash controls. Set the dash and forget......
Regards,
Stuart
FollowupID: 341601
Follow Up By: fatz - Monday, Nov 01, 2004 at 17:55
Stuart, I'm in Sydney and would love to have a look at your setup. Send me a mail at dslcruiserAThotmailDOTcom with a contact number and I'll give you a call.
Mick
FollowupID: 341614
Reply By: Member - DOZER- Monday, Nov 01, 2004 at 17:10
Hi The tap will be on the heat side of the system, so the hose that comes off your head is the one that will have the shutoff valve on it...
AnswerID: 82570
Follow Up By: fatz - Monday, Nov 01, 2004 at 18:02
Thought of that Dozer, but one comed from the back of the water pump and one comes from the block. I've figured out the flow direction so I'm guessing that the tap is before the heater box on the inward side.
Mick
FollowupID: 341616
Reply By: Baz (NSW) - Monday, Nov 01, 2004 at 17:18
Mick find which direction the water flows on your truck and thats goes to the in on the exchanger so it should be flowing out on your rig to in on the exchanger then out of the exchanger to in on your rig.
Mick go HERE it's not twine but same princible.
Baz.
AnswerID: 82572
Follow Up By: fatz - Monday, Nov 01, 2004 at 18:03
Thanks Baz, I'm getting closer, just want the temp a bit cooler on the water from the shower.
Mick
FollowupID: 341617
Follow Up By: flappan - Tuesday, Nov 02, 2004 at 09:24
Normally you would run the water from the motor in the opposite direction to the shower water.
To keep it slightly cooler , you can run them in the same direction.
(something to do with keeping in contact with hotter water longer ).
FollowupID: 341738
Reply By: Member - DOZER- Tuesday, Nov 02, 2004 at 22:30
Hi easiest way forward is to tee off the bloclk (which is hot end) and put your own valve on it so only when shower is in use you open it up. outlet is to the pump. ie the punp is suction and block is pressure.
AnswerID: 82809
Follow Up By: fatz - Wednesday, Nov 03, 2004 at 08:39
Thanks Andrew, thats what I was thinking, just wanted to be sure. Much appreicated.
Mick
FollowupID: 341878
