Water temp sender on GU
Submitted: Monday, Nov 01, 2004 at 16:56
ThreadID: 17475 Views:2370 Replies:4 FollowUps:3
Anyone know were the water temp sender is on the GU?? I've found two sensors near the thermostat housing on with one wire the other with 2 wires.
Reply By: theshadows - Monday, Nov 01, 2004 at 17:03
if its typical nissan the single wire is the temp sensor for the guage .The bigger 2 unit one is the ECU unit and opertate on 2 temp settings.with the motor running unplug the larger unit and sell if the aircon fan kicks in full bore. If it does means its trigged the safetly map setting and if its a turbo fired the safety boost range.
shadow
AnswerID: 82567
Follow Up By: Austravel - Monday, Nov 01, 2004 at 17:14
Thanks, it's a 4.2 turbo diesel so won't have an ECU unit will it.
FollowupID: 341604
Follow Up By: theshadows - Monday, Nov 01, 2004 at 17:53
should still be the same set up thou....small one single wire is the guage and the large will control relay or if you had a ecu the aircon fan. nissan is very good that way most sensors and wireing is standardised.
FollowupID: 341612
Follow Up By: Austravel - Monday, Nov 01, 2004 at 17:58
Thanks, I'm trying to find out if the sender measures the temp of the coolant or of the conducted heat in steel/alum. I'm pretty sure it will be in coolant by the looks of the position.
FollowupID: 341615
Reply By: theshadows - Monday, Nov 01, 2004 at 18:11
dunno old one are coolant...dunno about this new fangled units .
the small one is a viable restance one the large one is 2 combined set up to earth out at different temps.
shadow
AnswerID: 82575
Reply By: Truckster (Vic) - Monday, Nov 01, 2004 at 22:57
If its the same as the GQ TD42, the sender is the one closest to the radiator, the smaller one of the 2.. Its a 10mm head where the other is a 14 if I remember.
AnswerID: 82653
Reply By: Austravel - Tuesday, Nov 02, 2004 at 09:45
Thanks all.
AnswerID: 82699
