AnswerID: 82591 Submitted: Monday, Nov 01, 2004 at 18:16
Smocky
replied:
G'day Jeff,
I had exactly that annoying problem in a Nissan Pulsar would you believe. Every time I reversed out with the wheels turned and put the brakes on, a little knock almost like something clicking back across or something like that.
I never did find out what it was, so I'm afraid I'm not a lot of help this time but wanted to mention it all the same so as you didn't think it was unique. I even put my car up on stands and tried shaking the wheels. It never got any worse and this was from near new.
The knocking I heard didn't sound like bushes, more like metal joint with a bit of play and it moved from point a to point b and impacted on the other side. (If that made any sense).
Because it happened when I put the brakes on, I was convinced that the brake calipers were moving slightly, but I could never prove it. Give the brake and wheel assemplies a good look and see if there is any play in that area.
Hope you find it anyway. Drove me nuts.
Smocky
Reply 3 of 14
