80 Series headlight switch
Submitted: Monday, Nov 01, 2004 at 17:57
Goran
Something happened to my main headlight relay and in turn my headlight switch burned out. There is a heat damage to plastic casing. I have new one on order and luckily 80 series combination switch comes apart so you can change individual switches rather than forking out 500.00 or so for new combination swith. I took the steering wheel off and headlight swich can now be separated. There is a plastic cup/cover on the swich end and once taken off one can see plastic retainer.
Here is a question, i never done one of these before so do i have to destroy this retainer in order to get internals out or is there another way? Generaly, how do you replace this headlight / tail light switch ? Any info is appreciated.
Reply By: Member - DOZER- Tuesday, Nov 02, 2004 at 22:20
Usually they dont give you a problem....they only switch a small amount of current for the control side of things...i have a spare complete if u want to plug it in and try it out.
82803
Follow Up By: Goran - Wednesday, Nov 03, 2004 at 08:06
The switch is definately burned. I tested it. Thanks anyway.
341873
