Landcruiser
Submitted: Monday, Nov 01, 2004 at 23:01
japmel
I am looking at buying a 1999 Landcruiser diesel HZJ105R, can anyone tell me what series it is if any. and is there anything I should look out for.
Reply By: ross - Monday, Nov 01, 2004 at 23:28
A lot of these are ex mining or outback vehicles bought from auctions and cleaned up.Some are rollovers resprayed and look new but may come with a high cost to get the maintenance up to scratch.
Have a close look at the nuts and bolts for spanner wear.If lots of them show wear it may have been built up from used parts
Make sure the gearbox changes smoothly when warmed up.
Have a look behind the front
wheels for a mess.It costs about $600.
A $150 on an inspection would be a good investment if your spending $30k
I saw some ex navy 105s in WA recently and they would have to be the best around.
82660
Reply By: Member - 'Lucy' - Tuesday, Nov 02, 2004 at 03:17
Japmel
It is a 100 series.
82680
Reply By: fatz - Tuesday, Nov 02, 2004 at 07:09
japmel, have the same model. It's a 100 series body but is known as a 105. It's basically 80 series running gear with a 100 series body. This is the most basic model that was built in that range. Vinyl seats, mats and so on. As mentioned earlier the ex
mine ones can be a bit tired and have had a hard life.
Mine is ex
mine but I was able to find out a lot about it's backround because I knew the dealership who serviced it and the guy who used to drive it. The motor is the 1hz, same as the 80 series, if
well looked after (oil and filters every 5000k's) it will serve you
well. Gearbox can be a bit notchey in third, esp changing down. Diffs are usually good for 250 - 300,000 k's before rebuild but have been known to last longer. some of the later model 100's with Independant front
suspension have been known to blow the front diff. The model you are asking about should have solid front axle. Body is fairly sturdy on the105. not much trim to worry about and are easy to clean if you intend to get down and dirty. Door hinges tend to start to sag, especially the drivers door. Easy and cheap to replace. They drive
well but can be a bit slow on the long hills. Being the base model they dont have a great ammount of sound proofing so can be a bit noisey on the road but this depends on what tyres you run as
well. Have owned an 80 and sold it with 320,000 k's on the clock and bought the 105 18 months ago with 100,000k's on it. We have done 40,000k's in the eighteen months with no problems. A good and capable vehicle in my opinion
Mick
82687
Follow Up By: japmel - Tuesday, Nov 02, 2004 at 10:29
Thanks Mick for the responce.
The vechicle we are looking at has vinyl trim but cloth seats, has 163975k's on the clock and is a X-Government vechicle, comes with
snorkel, roofrack, bullbar, winch, etc, asking price $30k, in your opinion would it be a good buy.
Am looking at travelling Australia, towing caravan.
341752
Follow Up By: Member- Peter & Mrs Peter, Lez - Tuesday, Nov 02, 2004 at 16:42
Mick,
Was wondering in what way does the 80 series running gear differ from the 100 series running gear. I dont believe it is a 100 series body as the 100 series doesn't have
barn doors.
Cheers Peter
341796
Follow Up By: fatz - Wednesday, Nov 03, 2004 at 07:18
Peter, without going into too much detail and I'm no expert, 1hz motor - essentally same although toyota claimed max power of 96 kw @ 4000rpm for the 80 and 96kw @ 3800 for the "standard 100" Gearbox in my 105 is same as the 80 I had, (cant remember the model number I'll look it up later).
It's referred to as a 100 series on the offical toyota site. The base model does have
barn doors and is known as a 105
Check out this link for some use ful info
http://www.brian894x4.com/LC80.html
It'll gives all the specs
341870
Reply By: fatz - Tuesday, Nov 02, 2004 at 13:39
John, a bit dear in my opinion. I have seen simular a lot cheaper, one in Syd about two months ago for 26K simular K's. For 30k I would expect less K's but as I said earlier they are good for at least 300,000
82723
