chev 6.2 diesel
Submitted: Tuesday, Nov 02, 2004 at 00:24
ThreadID: 17493 Views:5060 Replies:13 FollowUps:3
g'day all,any one have any info on the chev. 6.2 diesel going into a 95 model troopie? i am thinking about doing the upgrade to pull a 18 foot van or should I just fit a turbo?(250000 klicks on the clock) thanks folks, Troopie1
Reply By: Bob H - Tuesday, Nov 02, 2004 at 00:46
pretty sure it can be done. check with some suppliers of the engine as they usually also do fittings. it would be an awesome machine but would the cost of it all be sensible compared to rebuilding your motor and fitting a turbo or replacing with an low milage turbo from the wreckers. i have a 1hz 80 series towing a 19ft full size van and it does it allright except on hills of course but then who really cares about going fast. your decision really and if you go ahead with the chev conversion i think many would be interested to know the results of before and after etc.
regards
AnswerID: 82671
Reply By: Truckster (Vic) - Tuesday, Nov 02, 2004 at 00:57
All depends on your budget.
Conversion will cost you about $13,000 where a turbo will cost you $4000...
AnswerID: 82672
Follow Up By: Member - Chris M (QLD) - Tuesday, Nov 02, 2004 at 10:27
Agree with T.
However, initial cost may be $4,000.00, but depending on the existing stuff, pump may need rebuild, clutch may suffer from extra power, old radiator may not be up to job etc.
Set aside $6000 just to be sure, and you'll have $7000 in your pocket to spend on your next trip! ;-)
FollowupID: 341751
Reply By: Member - 'Lucy' - Tuesday, Nov 02, 2004 at 03:11
Troopie 1
I was over at Piranha (Melb) approx 2 yrs ago and a dude pulled in with a 75 series flat top that he had just put what he called a 'small hummer diesel' into.
From memory he said it was a 6.4 diesel Chev motor, no doubt the same thing you are talking about.
It fitted OK (just) and he used a MARKS adaptor kit to mate it to the transmission. He also muttered something about it allegedly being able to do 200kph plus.
I am guessing, but I reckon you would need extra fuel tanks as it looked a 'thirsty' mother.
Ken Robinson
AnswerID: 82679
Follow Up By: Truckster (Vic) - Tuesday, Nov 02, 2004 at 11:54
theres the 6.2 and 6.5 diesels...
the 6.5 being the newer and apparently better.. theres a dude on outerlimits that does the conversions as a business
FollowupID: 341757
Reply By: Wok - Tuesday, Nov 02, 2004 at 06:33
Troopie1,
Got a 6.2 in a 60 series wagon...4 yrs now
Lots of torque in low end; 8-8.5km/l half ton load East coast [high density diesel] worst was 6.5km/l in Darwin [crap Asian fuel]
I have heard reports about conversions going through clutches [1st gear is now VERY torquey]...couldn't justify the $ for a longer tooth.. really needs a longer 5th/overdrive as 100km/hr is just past the 'optimum' economy range....can't see 200km/h unless it had a custom box [ I think mine redlines @ 3500rpm]
Problems:1. I think I am up for injector/pump work [staggers & hunts around 1200rpm]
2. Belt fitting is a pain
3. Fitted 2 fuel pumps
I think if you intend to fit the unit yourself you could get it 'just right' [ in particular the alternator] Chev recommends 2 starting batts...found 720cca just short. You will need a good radiator or it will overheat on hill-climbs [the Melanie & Toowoomba ranges catches mine out.
Hope this helps
AnswerID: 82682
Reply By: Member - Jack - Tuesday, Nov 02, 2004 at 06:36
Check out Post 17272.
Jack
AnswerID: 82683
Reply By: Utemad - Tuesday, Nov 02, 2004 at 09:13
Guys in our club tow 2 tonne offroad vans with 1HZ 80 Series Cruisers. Slow on hills but fine everywhere else.
AnswerID: 82695
Reply By: troopie1 - Tuesday, Nov 02, 2004 at 14:17
thanks all for the quick response,reading the feed back I might just take the advice on the turbo & engine (4.2 ) still would have been awesome in the red stuff!thanks again for feed back, see ya out there.. troopie 1
AnswerID: 82727
Reply By: Drew - Karratha - Tuesday, Nov 02, 2004 at 15:28
Check out Brunswick Diesels in Brunswick Junction - they supply and fit the 6.2 and 6.5l Chevy v8's. They have a great reputation and I havent heard anything but positive comments about them. (I think they also fit turbos to them - imagine what a beast the troopy would be then!!!)
Drew
AnswerID: 82735
Reply By: Bryan (WA) - Tuesday, Nov 02, 2004 at 17:00
A Friend had his 4.2 deisel GQ patrol converted to the chevy 6.5 at Brunswick Deisel. They do a very professional job, very impressive power and torque outputs.
it certainly makes me want to convert my GQ over to one also!!
He also have the diff ratios changed over to the patrol 4.8 ratios - Brunswick do this converstion, and that made a huge difference in driveabiity when touring, as it now revs at 2200 doing 110kph as opposed to approx 2600 at 110kph..
AnswerID: 82742
Reply By: Coops (Pilbara) - Tuesday, Nov 02, 2004 at 17:01
I believe the 6.5 is a better option as 6.2 has overheating issues.
Know of a guy in Pilbara who did this conversion (started with 6.2 and then went to 6.5) in a 75 series troopy. Awesome machine. My brother has 6.2 in his 60 series - again an awesome machine but fuel pump issues.
Nothing too serious but issues all the same.
Looking at the same conversion into my 80 series (6.5 that is)
Hope this helps
AnswerID: 82743
Follow Up By: Wok - Tuesday, Nov 02, 2004 at 21:03
Coops,
What is/was the fuel pump issue your brother had in his 60 series? Sounds like he had much the same 'issues' I have. Why do you expect the 6.5 to run cooler?...I would have thought that is a radiator problem?
rgds
FollowupID: 341828
Reply By: colin - Wednesday, Nov 03, 2004 at 18:01
you also have to consider your insurance as a lot of companys wont insure these changes, also they are very noisey motors inside the cab. Col
AnswerID: 82906
Reply By: Jim-Bob - Wednesday, Nov 03, 2004 at 20:38
G'day Troopie1
Try this web site
lindquip.com.au
Safe travells
Jim-Bob
AnswerID: 82916
Reply By: V8Diesel - Saturday, Nov 06, 2004 at 00:11
Got a Brunswick 6.5V8 in my HJ75 and a Detroit Locker diff. It goes pretty well. Could do with a slighly taller 5th though. Just had to replace the clutch with a HD item.
Not as sophisticated as a Jap turbo, but HEAPS more fun. Just wish I could get a Detroit 8V71 and an Alison under the bonnet - now that'd be a combo.
AnswerID: 83199
