Nissan Engine Oil
Submitted: Wednesday, Nov 03, 2004 at 07:50
Hardo
Hi all
For those that change their own engine oil, what oil do you use for Nissan 3Ltr TD?
Hardo
Reply By: 3.0turbob - Wednesday, Nov 03, 2004 at 08:11
Hardo,
I change oil & filter in
mine every 5000k's using Nissan Diesel Oil and nissan filter.
Whtever oil you decide to use, makesure it meets Nissan specs. Check your vehicle handbook. Never use APIC-G4
Rob
82848
Reply By: Billy - Wednesday, Nov 03, 2004 at 08:11
Castrol GTX3, economical, easy to find, meets specs (15W40 CF). Up to a year ago it was on the recommended list at the Castrol web site but was replaced by a later released oil, still OK by them though (I checked). As (unfortunately) most of my daily use is urban, I change at 5K.
Regds
Bill
82849
Reply By: 80scruiser - Wednesday, Nov 03, 2004 at 12:45
Strongly recommend to use 10w30 or 5w30 SL.
Change every 5000 km.
82879
Follow Up By: Leroy - Wednesday, Nov 03, 2004 at 12:49
Not sure they meet the spec. From memory I thought it was a 15-40 viscosity.
Leroy
341905
Follow Up By: 80scruiser - Wednesday, Nov 03, 2004 at 18:04
Your owners manual states the grade oil you should use for the given temperature you will expect to operate in. It also states a recommended grade for best fuel economy which will be the lighter grade oil but this oil will be no good if you operate in
the desert.
341929
Follow Up By: Leroy - Wednesday, Nov 03, 2004 at 22:10
The manual states:
For cold area's 15w30 is preferable (+/-20 degC)
5w30 for below zero
I personally use a 15w40
Leroy
341956
Reply By: Member - toohey - Wednesday, Nov 03, 2004 at 17:03
gidayhardo ,nissan sold me castrol magnatec.regards toohey
82901
Reply By: Member - Andrew(WA) - Wednesday, Nov 03, 2004 at 20:46
Castrol Super RX 15-W40
Was used by my dealer and I use it every 5000
82918
