Dual Battery setup on 4Runner
Submitted: Friday, Nov 05, 2004 at 13:26
ThreadID: 17567 Views:5040 Replies:6 FollowUps:3
Hi guys,
great forum,
I am looking at Putting a dual battery system in my 4runner but dont think it will fit?
Anyone tried it out there
kata
Reply By: Member - Kerry (VIC) - Friday, Nov 05, 2004 at 14:09
petrol or diesel?? i have the diesel fits fine have to move the water washer bottle a bit further up and is a tight fit but overall fits well looks neat.. also have to remove both batteries to get to the light globe.. only problem i had was that the terminals were a little high and used to hit the bonnect thus shorting things out make sure you make it as low as possible..
need any help let me know
AnswerID: 83132
Reply By: Kata - Friday, Nov 05, 2004 at 14:39
thanks Kerry,
petrol v6
so did u move them perpendicular to where it sat originally to get them both in??
what batteries you using...
How did you overcome the shorting issue
thanks
Kata
AnswerID: 83136
Reply By: Member - Kerry (VIC) - Friday, Nov 05, 2004 at 15:03
if your facing the front of the car you move the water bottle and bracket back about a foot and turn the bateries long ways im using delco 520 batteries they sit flush next to eachother. the battery tray that was in my car when purchased was about 2inch thick which caused to terminals to kiss the bonnet (took me ages to work out what was wrong) made a custom tray and put some caps over the terminals (rubber) got them from local servo.. ill try to organise a pick for you tonight..
AnswerID: 83142
Follow Up By: Kata - Tuesday, Nov 16, 2004 at 20:26
Kerry
by any chance you got a few/or a pic of the dual battery setup yet???
kon_k@iprimus.com.au
FollowupID: 343349
Follow Up By: Kata - Tuesday, Nov 23, 2004 at 00:43
Hi Kerry
Any luck with the pics yet bud
regards
Kon
thanks
FollowupID: 344033
Reply By: Tuco - Friday, Nov 05, 2004 at 22:06
The Surf - which is much the same as the 4Runner already has 2 batteries - factory fitted. If you can get a squizzy at one of these, you may get an idea of just what is different with yours. I think that the 4Runner airbox is where my Surf (KZN 130W) left battery is situated - maybe a different (or Surf) airbox is what U need.
AnswerID: 83189
Reply By: Longy - Wednesday, Nov 10, 2004 at 13:02
I've got a 1995 Rv6 4runner. Asked around local places and they told me I couldn't fit a dual battery setup in. I didn't belive them so I went to another dealer and asked, he said it's not a problem. just have to use a smallish bettery, but better still to have two batteries than one flat out in the bush.
It sits on the drivers side wheel arch behind the original battery. SO far haven't had a problem and the battery has helped me out to run laptop, lights and uhf etc. So far can't complain. Just ask around a few places there are some willing to help and others not after your business.
Cheers.
AnswerID: 83853
Follow Up By: Kata - Tuesday, Nov 23, 2004 at 00:42
Thanks Longy
You wouldnt be able to get me a pic or 2
That would be greatly appreciated
Melb based
cheers and thanks
FollowupID: 344032
Reply By: enzo- Tuesday, Nov 30, 2004 at 22:51
Here's a pic of my UK 4Runner 3.0TD:
http://www.elphick-pooley.co.uk/htm/enginelectrics.htm
Two batteries, one starter, one accessories, thinking of putting a third in: second starter battery in parallel.
enzo
http://www.bundubasher.com
AnswerID: 86690
