Calibrate speedo/Larger Tyres
Submitted: Friday, Nov 05, 2004 at 22:52
Member - Phil F (WA)
Hello peeps...I just put some BF Goodridge 315R7516 Mud Terrians on the Beast (100 series Crusier) as where approching the wet season up north and ill be heading off there shortly again... and the speedo is out by around 10k's , possibly more...I need to know if anyone in WA can direct me to someone that can calibrate the speedo...
Well that's what i think needs to be done..Not to sure....So i'm hoping a few people may have been in the same situation and they might be able to point me in the right direction....
Looking forward to your remarks...
Reply By: Mike Harding - Saturday, Nov 06, 2004 at 06:50
Many speedometers seem to over-read by anywhere from 5 to 10% so before having it recalibrated (is that possible without major changes?) try and borrow a GPS and do some tests.
Mike Harding
83209
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 12:17
Thanks Mike...I'll give that a go...
342214
Reply By: Member - Blue (VIC) - Saturday, Nov 06, 2004 at 09:37
G'day Phil,
anyspeedo specialist should be able to do the work. I had a gearbox made up for the Rocky I had a few yeas ago with 31's on it. It cost me about $60 and was simple to remove when I put the stockies back on. All up the contraption was about half the size of a smoke packet.
Blue
83216
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 12:19
Thanks Buddy...Trying to find a speedo specialist seems to be the problem...Ive been to several Toyota Crusier dealers and they have no idea...
Ill keep looking...
342215
Follow Up By: Member - Blue (VIC) - Saturday, Nov 06, 2004 at 15:25
You should move to
melbourne Phil, then I know of only 2 here so they are probably few and far between. Have you tried a gearbox reco place, they may have an idea of who can do it.
Blue
342233
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 15:40
Hello Blue Mate...Might have to go to
Melbourne to get the problem sovled lol....Cheers mate...I'll have a look at the Gearbox
Places Monday as
well as a few others peeps have sugested...
342238
Reply By: Penguin (NSW) - Saturday, Nov 06, 2004 at 10:44
Hi Phil
This website is a great tyre size calaulator. Gives circumferences, speedo error etc.
At least you'll know how far out it really is.
Mike
83222
Follow Up By: gonebush - Saturday, Nov 06, 2004 at 12:04
The problem with that website is that, although it correctly calculates the difference in speedo readings with different size tyres, it assumes that the speedo is correct/accurate with the stock tyre fitted.
This is not necessarily the case.
For example a GU, with the stock tyres fitted (265/70/16 from memory), actually travels about 7% slower than what the speedo says. If the speedo reads 100, you are actually travelling about 93 khph (measured with GPS which is accurate to around 0.01 kph) Fit 285/75 /16 or 305/70/16 tyres and the speedo will now read almost the same as the actual speed.
This also causes fuel consumption figures to be inaccurate......with standard tyres you will think you are getting 7% better fuel consumption than you actually are because the speedo gives a higher km travelled reading than actual.
342212
Follow Up By: Bonz (Vic) - Saturday, Nov 06, 2004 at 15:04
My GU with stock tyres (265/70) is spot on the GPS speed readings
342229
Reply By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 12:22
Thanks Peeps...Now im getting a little more confused..he he...I dont have a GPS at the moment so ill have to try and get hold of someone in WA who can help me with this...I really need to get it sorted otherwise it could cost me big bucks in speeding finds...
83227
Follow Up By: Mike Harding - Sunday, Nov 07, 2004 at 07:16
Don't forget the old ways if you can't access a GPS. A stopwatch and a straight road, the distance of which you can establish from a map - you must have a few of those in WA? :)
Mike Harding
342327
Reply By: Member - Jimbo (VIC) - Saturday, Nov 06, 2004 at 13:01
Try calling a diff specialist. When lads want a bit more accelleration out of their car they often go for a lower ratio diff. Any diff specialist will be able to put you in contact with someone who corrects the speedo.
Went through this exercise with my son's car.
Jim.
83230
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 13:18
Thanks Jim....I'll have a look around and see who can do what...
342222
Reply By: Coops (Pilbara) - Saturday, Nov 06, 2004 at 14:57
Phil - I believe there's a mob in Balcatta called Applied Instruments (I think that's the name) and I've been told they can help
83240
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 15:38
Thanks Coops Mate...
Apprecaite that...I'll go there on Monday and see what the damage will be....Heading up your way in a few weeks...Will have to catch up mate...
Cheers Phil
342237
Reply By: Member - Brian (Gold Coast) - Saturday, Nov 06, 2004 at 15:21
Simplest/cheapest way is to either:
A) Use a GPS to display your "correct" speed.
or alternately
B) Use a mate who has a GPS or just an accurate speedo
Either way, drive at various speeds (When using "B", maintain radio contact and get your mate to call the speeds) and label your speedo at the various "common" points
I.E
40
50
60
70
80
100
110
etc.............
You could for instance use arrow decals or dymo labels etc.....
83242
Follow Up By: Member - Phil (WA) - Saturday, Nov 06, 2004 at 16:01
Thanks Brian...I will try a few
places people have sugested before going down that path...But a good idea...
Many Thanks
342240
Reply By: craig - Sunday, Nov 07, 2004 at 12:09
Hi Phil,
just reading your post and though of this mob in WA as they were quite helpful when I was asking them about converting my imported range rover speedo from MPH to klm's
http://www.aisat.com.au/
craig
83341
Follow Up By: Member - Phil (WA) - Sunday, Nov 07, 2004 at 13:28
Thanks Craig....I'll give them a go...cheers...Appreciate the help...
342367
Reply By: charlie - Sunday, Nov 07, 2004 at 18:25
Hey Phil how does the cruiser go with the new tyres. Does it handle the increase in tyre size without losing too much power. What type of cruiser is it a petrol/diesel, auto/manual?
Charlie
83369
Follow Up By: Member - Phil (WA) - Sunday, Nov 07, 2004 at 18:39
Hello Charlie...Well so far so good mate...I'm off to the bush very shortly so i'll let you know when i get back...My cruiser is Petrol mate and there's plenty of power...It's also a auto....Just the speedo thing i want to get under control...Power is no problem...
I'm also looking at raising the Beast another 3 inches tomorrow as well....
342383
Reply By: gonebush - Monday, Nov 08, 2004 at 09:55
Hi Phil,
Can't send you a message as it's a 'Members only' function.
I could help you out with a GPS if you like. I'm in the Northern Suburbs
I can't send you a message, so if it's convenient you would like to email me at gonebush@bigpond.net.au
regards
83464
