GQ PATROL 4.2L PETROL TEMPERATURE PROBLEMS
Submitted: Saturday, Nov 06, 2004 at 17:35
david
I HAVE A TEMPERATURE PROBLEM AT HIGH RPM 4500-5500RPM
SHOULD IT GET HOT? NORMAL TEMPERATURE A WHISKER BELOW 1/2
BUT SHOOTS UP PAST 3/4 WHEN I REV UP TO OVERTAKE OR JUST BLOW THE COB WEBBS OUT OF IT.
DOES ANYONE HAVE A SOLUTION?
COOLANT FINE
WATER PUMP IS ALSO FINE WHAT ELSE COULD IT BE?
Reply By: Ferret - Saturday, Nov 06, 2004 at 18:09
To much SHOUTING, and
mine is cooler than just below half for normal driving so you may have a problem across the whole range...Fan hub???
Scott
83257
Reply By: Shaker - Saturday, Nov 06, 2004 at 18:10
I must be going crazy, I thought you posted this question yesterday & got several answers!
& btw ..... DON'T SHOUT!
83258
Reply By: Mick - Saturday, Nov 06, 2004 at 21:00
I think faulty fan hubs only cause problems at low speed. I presume that at 4500-5500RPM the air flow from motion is considerable. If that's the only situation which leads to a rise in temp then I think the cooling system is just not up to the task - I've known other Patrol owners who've had similar problems. By the way if it's just becoming warmer and not actually overheating then it's not a problem.
83284
Follow Up By: Flash - Sunday, Nov 07, 2004 at 18:48
re the fan -Wrong.
Faulty viscous fans can cause problems at almost any speed.
Maybe less noticeable at highway speeds, but still a factor.
As I said in an earlier post, the viscous fan is the most common source of overheating problems.
342384
Reply By: crusher - Saturday, Nov 06, 2004 at 21:23
Check your lower radiator hose, as they can suck closed at high RPM
83287
Reply By: Vinnie - Saturday, Nov 06, 2004 at 21:51
At that Rev range - Yep it's gonna get warmer!! Does it drop back when you lower the Revs?
83294
Reply By: Bryan (WA) - Sunday, Nov 07, 2004 at 00:20
I think you may find your radiator core might be blocked/old and giving up the ghost.
Mine last summer ran hot jsut driving on the freeway.. had it checked and basicly the core was coming away from the fins.. basicly age of the unit and dirt that couldnt be washed away taking its toll..
go get your radiator preasure tested, it is mostly likely that.....
regards
Bryan
83311
Reply By: Brew69(SA) - Sunday, Nov 07, 2004 at 20:52
Wow, i must baby minw too much.......didn't know it was capable of so high revs. I rarely use more than 3500 rpm even in soft sand.
Mine heats up a bit when doing long low range stints. Could be a blocked radiator for yourself.
83387
Reply By: stephenjNQ - Tuesday, Nov 09, 2004 at 21:22
david , i reckon flash has the answer,had a work hilux do the same thing replaced fluid in the fan clutch ,no more problem. i have a gq patrol petrol at the moment and when you work it in sand or up hills starts to cimb on the temp gauge , the fan clutch is leaking oil from the seal . so time for a new one. sorry for the late reply . regards stephenjNQ
83770
