Trailer mover
Submitted: Monday, Nov 08, 2004 at 09:17
Member - big bo (NSW)
Can anyone inform me of the best, easiest and cheapest way to move your camper trailer around when it is not connected to your truck.
Thanks.
Reply By: cokeaddict - Monday, Nov 08, 2004 at 09:37
Easiest way would be to push it....HARD !
But if we eliminate the "cheapest" part of your question, then i have a friend who runs a 12V electric motor off his front wheel. Chain and sprocket job with low speed with lots of torque. Works a treat he tells me. Especially when offroad with a full load in it. Nothing worse that trying to move a fully loaded trailer on damn grass.
83461
Follow Up By: beatit - Monday, Nov 08, 2004 at 10:46
Is this a home made job or one off the shelf? Like the sound of it.
Kind regards
342465
Follow Up By: cokeaddict - Monday, Nov 08, 2004 at 13:31
It was a home made one, worked a treat. But reading the other replies here it sounds like someome actually sells one. Maybe he copied it from one he saw on the market.
342473
Reply By: Well 55 - Monday, Nov 08, 2004 at 09:40
The big cavaran
places sell a rachet type jockey wheel that will move a large van, worth a look I reckon.
83462
Follow Up By: Member - Blue (VIC) - Monday, Nov 08, 2004 at 10:09
there always seems to be a couple of these floating around on ebay... usually for about $80
Blue
342459
Follow Up By: flappan - Monday, Nov 08, 2004 at 10:45
I've got one of these. Called a Power Wheel.
Was given to me by my parents cause it wasn't big enough to push their offroad Cvan , but does a perfect job on my CT.
They bought the original "Power Wheel" twas several hundred $$ back then I think. I have seen them (knockoffs ) for about $130, from memory.
I found it evry handy for moving the CT around and for attaching to vehicle. Nothing worse then being only a couple of cm's out. Use this.
Definently recommend.
342464
Reply By: Truckster (Vic) - Monday, Nov 08, 2004 at 10:28
What sort of ground are you talkign about? Muddy garden? Grass? Concrete?
83472
Reply By: Member - Captain (WA) - Monday, Nov 08, 2004 at 11:12
Hi Big Bo,
I use a ratchet type jockey wheel on my 1.6T van. It works
well on hard surfaces and grass, but obviously it struggles (
well, becomes hopelessly bogged!) on soft sand. You need a bit of weight on the drawbar when going uphill (mild slopes only) but works a treat for general manovering.
Also makes it real easy to reconnect the van. I have a treg hitch and thats a bugger to reconnect unless on level bitumen.
Captain
83477
Reply By: Truckster (Vic) - Monday, Nov 08, 2004 at 12:12
Towbar on the front of the car?
83484
Reply By: Member - Roachie (SA) - Monday, Nov 08, 2004 at 15:47
Probably too expensive but it got my attention at the time.......
At the
Adelaide camping show last year there was a bloke there flogging a remote-controlled gizmo. It worked on both main
wheels (as opposed to a jockey wheel) of the camper or trailer. It utilised 2 electric motors which sat up behind the
wheels at floor level and each one had an extended shaft with a small drive wheel, which he could activate indepandantly from one another. He could just about make the trailer do a dance!!! The drive wheel rested against the tyre's tread.
He had a ramp set-up which was only slightly wider than the track of the trailer and he was able to "drive" the trailer up and onto the ramp, even at at angle whereby one wheel would hit it before the other. Very ingenious I thought. Not sure how practical it would be to have it hanging there when not in use; however, I also thought it could possibly be of some use to give some small amount of traction to a trailer when traversing mud or
sand dunes etc. (of course the speed was not great, but the fact they were being driven at all would have to be bonus).
83513
Follow Up By: Lone Wolf - Monday, Nov 08, 2004 at 17:18
Yes, that was a treat to watch, and the best thing, you could steer the van / trailer only using the remote control. It would turn in it's own diameter, and it didn't matter how slippery the ground was, it was driving the main
wheels, with the weight on them.
I can't remember who was handling this thing, but it was a gem. Won't work with tandem axles though.
Wolfie
342490
Reply By: pjd - Monday, Nov 08, 2004 at 20:59
ezi move jockey wheel by ark @ $180 will take a 350kg down load & move a couple of tonne easily
83556
