GQ SWB Vibration
Submitted: Monday, Nov 08, 2004 at 17:16
ThreadID: 17641 Views:2061 Replies:2 FollowUps:2
Hi everyone, I'm a new member...
I currently have a swb maverick with a 2inch suspension & 2 inch body lift in it. I've got the usual tailshaft vibration that you seems to get with any kinda lift that you put in a shorty. In a previous shorty that i had I put 30mm spacers under the gearbox & that seemed to remedy the problem & I see that Big Balls Offroad have a similar type of thing with some steel plate. If there is anyone that has tried something different other than the spacers I'd be greatful for any suggestions...
Bench
Reply By: Member - Chris M (QLD) - Monday, Nov 08, 2004 at 17:20
Welcome to the fray benchy!
Are you happy with the body lift?
AnswerID: 83527
Follow Up By: Voxson (Adelaide) - Monday, Nov 08, 2004 at 22:13
Hi Chris... You really gotta finish that vehicle off with some larger OD rubber...It is all it is missing....
FollowupID: 342520
Reply By: Truckster (Vic) - Tuesday, Nov 09, 2004 at 13:02
As you say all shorty GQ's suffer from suspensino lifts.
But it varies from truck to truck..
EG theres some 7+inch lifted with little hassles (or so the owners say) just caster plates.
Liam at Bigcods has some great gear, try the packers if they worked befoer, try them again, you have nothing to lose...
AnswerID: 83666
Follow Up By: Bench - Tuesday, Nov 09, 2004 at 13:25
thanks. i might give the drop down plates a go... have always got the packers to fall back on, if it all goes pear shaped.
FollowupID: 342573
