oil light in GQ Patrol?
Submitted: Monday, Nov 08, 2004 at 19:10
Member - William H (QLD)
Recently became a member of this
forum and wonder if anyone out there can shed some light on a problem I currently have. My vehicle is a 91, 4.2 Diesle TI.
The problem I am experiencing is that I have pressure on the oil guage but the
little red light on the dash will not go out.
Would anyone have any ideas as to what the problem can be???
gq42
Reply By: awill4x4 - Monday, Nov 08, 2004 at 19:22
Classic problem with Nissan oil pressure sender. I have found in the past a gentle blowing out with compressed air can help but if this doesn't fix it then it's time to replace it with a new one from Nissan. Because it registers on both gauge and warning light there is nothing available aftermarket so genuine Nissan is the go.
Regards Andrew.
83541
Follow Up By: Member - William H (QLD) - Monday, Nov 08, 2004 at 19:42
Thanks for that
awill4x4
342500
Follow Up By: Brew69(SA) - Monday, Nov 08, 2004 at 21:53
WRONG.there is an after market option...........go to repco and ask for navara sender.cost $18.........
342511
Reply By: Brew69(SA) - Monday, Nov 08, 2004 at 21:03
Yes there are 2 senders.one connected to light and one to guage.both are crappy and always fail.....replace with new one ($) never problem again.
83557
Reply By: Truckster (Vic) - Monday, Nov 08, 2004 at 21:15
Oil sender as Andrew said.
$90 when I got one 18 mths ago from Nissan...
83561
Reply By: theshadows - Tuesday, Nov 09, 2004 at 09:15
This is a proplem with nearly all nissan's with high kms on the sender units.Ive have very good success with drilling out the sender units to 1.5mm, then cleaning them. It works on the guage units as
well as thelgt units.
shadow
83630
