WINCH PARTS
Submitted: Tuesday, Nov 09, 2004 at 13:13
locallaw
Gidday All.I have a Warn XD9000 sitting in the shed that needs rebuilding.What I am afteris where can I buy the parts I need.
Just as a side note I have just returned from NZ where the price of fuel is ridiculous. I paid up to $1.40 lt unleaded and 83 cents for diesel.
Seeya Locallaw
Reply By: Peter - Tuesday, Nov 09, 2004 at 13:21
what about trying the distributor for warn
winches,he might have some parts www.arb.com.au
83671
Follow Up By: Leroy - Tuesday, Nov 09, 2004 at 13:35
I think you will find the distributor is Ateco.
Leroy
342575
Reply By: AT4WD ADVENTURES - Tuesday, Nov 09, 2004 at 13:33
Hey Outlaw,
Where are you located?
Stuart
83675
Follow Up By: locallaw - Tuesday, Nov 09, 2004 at 13:38
Stuart,Mackay.
Locallaw
342578
Follow Up By: AT4WD ADVENTURES - Tuesday, Nov 09, 2004 at 13:43
Stuart,
The distributor is indeed Ateco and not sure if you have these guys up there. You can however buy parts from resellers such as ARB etc. I have been going through the rebuild process myself for the 2nd time in 8 years of the exact same winch. What parts are you after in particular?
Regards,
Stuart.
342580
Follow Up By: locallaw - Tuesday, Nov 09, 2004 at 13:49
Stuart.I need brake ass,drive shaft,spacer bars etc.This winch has a hard life and not looked after.Was my son-in-laws.
Seeya Locallaw
342584
Follow Up By: AT4WD ADVENTURES - Tuesday, Nov 09, 2004 at 14:20
Stuart,
The reason I ask what parts you needed was that I could give you an idea of cost for the various parts so you can make up you mind as to whether its cheaper to rebuild or buy a new winch. The brake assembly for instance is worth a bunch of money.
Regards,
Stuart.
342595
Reply By: Peter 2 - Tuesday, Nov 09, 2004 at 19:03
Another source of s/hand parts is your friendly 4wd repair
shop, sometimes they will have a winch with a burnt out motor or know of a customer with one which can be pillaged for bits.
83740
