alloy wheels for ifs 100 series & strength V steel
Submitted: Friday, Nov 12, 2004 at 15:33
fozzy
would anyone know (would assume they are) if 100series ifs alloy rims(genuine) are same offset as steel(genuine)??????
also has anyone had any toyota alloy rims from 80 or 100 series crack,buckle or dent in their experiences and if so would you think a steel one may have survived?
just thinking about putting alloy ones on rear wheel carrier as have been told there is huge weight difference between alloy and steel
in past have always gone steel for strength but these days not so sure as been huge improvements in way alloy stuff designed and made
opinions and scenarios greatly appreciated
Reply By: NissanofOld - Friday, Nov 12, 2004 at 16:36
There are significant weight differences between alloy and steel. I know, I have a set of mud tyres on steel rims and road on alloy. With independent
suspension, wheel weight is very important, as this type of
suspension relies on the least amount of unsprung weight. I don't know if the 100 series has ever come with steel
wheels, but I would be surprised if it did. Alloy
wheels are also very strong and can take a fair pounding before breaking. I've never had it happen yet and I've done some pretty awful stuff over the years.
84131
Follow Up By: Member - Gary W (VIC) - Friday, Nov 12, 2004 at 17:18
I have a 100 Series T/D IFS it came std with Steel
Wheels.
Alloys are standard on the Sahara and came on the
Kakadu
Gaz
342999
Follow Up By: NissanofOld - Friday, Nov 12, 2004 at 17:26
OK, I admit that don't know much about them, but didn't think that was the case, as the whole point about IFS was reducing unsprung weight for better performance. By the by, is yours second-hand and could the seller have taken off the alloys, as I thought that the TD was higher up the food chain?
343000
Follow Up By: fozzy - Monday, Nov 15, 2004 at 07:51
thanks everyone for responses
ps: steel rims are standard on gxl and the alloys come as option
343167
Follow Up By: Member - Gary W (VIC) - Monday, Nov 15, 2004 at 08:31
NissanofOld,
Mine was new. Stell
wheels were std. - That was in May this year.
Gaz
343173
Reply By: Rigor - Friday, Nov 12, 2004 at 16:37
Hi Fozzy , a mate has a 100 series with toyota alloys and out of the blue one developed a crack . Was strange at the time as it is not used for what you would call extreme off road work. That is the only incident that I have heard of , I agree with the weight saving philosophy , the more weight one carries the more things break.
Cheers Dave L.
84132
Reply By: Member - Gary W (VIC) - Friday, Nov 12, 2004 at 17:21
Weight is always a factor but surely wheel weight is different to extra weight elsewhere as extra wheel weight doesn't load the
suspension. I didn't think the weight difference would be that significant. How many Kgs are we talking?
Gaz
84138
Follow Up By: fozzy - Monday, Nov 15, 2004 at 07:56
gary
have twin wheel carrier on back and considering weight saving there with alloys
dont have alloys so not sure of weight difference but would assume there is signifcant weight saving with alloy
so if alloy and steel have same offset(assume they do ) and i havent had puncture in last 7 yrs(pretty lucky-but tyres always in good nick) then weight saving worthwhile
with weight of steel hanging off back u get seesaw effect (leveridge) over rear
343168
Reply By: NissanofOld - Friday, Nov 12, 2004 at 21:43
Wheel weight contributes to unsprung weight (ie weight not supported by
the springs) which can make a significant difference to vehicle handling (that is
suspension movement, reaction time, spring response etc). The reason for IFS is to reduce unsprung weight and provide for generally better handling and ride.
I have driven the VX Cruiser (standard
suspension) and only noticed, what to me was a marginal difference in overall handling (compared to my Patrol with OME). Roll tended to be slightly greater, not as if the vehicle was under lesser control, but ride was slightly softer. The difference was surpisingly minor.
I could go and weigh my steel and alloy
wheels, but don't really feel like it. Suffice to say that the difference is significant; a steel rim weighs a heap more than an alloy.
84160
Reply By: Croozer - Friday, Nov 12, 2004 at 23:54
I have a set of 5 alloys for my 04 100 TD cruiser with road tyres and a set of 6 standard steel
wheels with 285 AT's for off road use. When I wear the road tyres out I think i'll put the 285's on the alloys for off road use. Have you ever lifted a 285 75 16" on a steel wheel onto a wheel carrier or worse, a roof rack, they are bloody heavy. The alloy is much lighter. I think the original reason most people use steel for off road is 1/ they can be straightened with a hammer if dented, 2/ they are not easily damaged by tyrepliers etc. Nowdays though, most people carry 2 complete spares so if a wheel is damaged or punctured they replace it and get it fixed at the next opportunity.
Having 2 alloys on a rear wheel carrier would be a significant weight saving.
Stu
84177
Follow Up By: fozzy - Monday, Nov 15, 2004 at 08:55
certainly know what it was like to get spare steel onto roofrack
bad enough onto rear wheel carrier
343176
Reply By: Utemad - Saturday, Nov 13, 2004 at 17:26
I have two sets of
wheels. 16x6 standard 97 Rodeo steel with 225/75 16 and 15x7 ROH steel with 31x10.5. Both have all terrains and I can tell you that the standard Rodeo steel
wheels with smaller tyres are much heavier than the ROH steel
wheels with the bigger tyres. Never weighed them but when you lift the two it is quite obvious.
The
wheels may cancel out size wise as one is inch more diameter and the other inch wider but the Rodeo rims are still heavier.
So not all steel
wheels are created equal.
84233
Follow Up By: Leroy - Saturday, Nov 13, 2004 at 20:29
Rodeo
wheels are heavy. I didn't realise until I bought some ROH trak2's!
Leroy
343068
