nissan 3.lt 2003
Submitted: Friday, Nov 12, 2004 at 18:12
ThreadID: 17761 Views:2283 Replies:4 FollowUps:1
gidday all
the oil in my motor takes long time to drain to sump for level check,standing over night,spot on in the morning. after one hour from shut down shows half way between add &full change oil&filter every5000.
is this the same for other 3.lt owners
regards toohey
Reply By: Member Eric - Friday, Nov 12, 2004 at 23:26
Toohey , you need to get your motor hot and then drain oil . If the oil cools down , it takes yonks to come out
AnswerID: 84175
Follow Up By: fisho64 - Saturday, Nov 13, 2004 at 00:01
you also want the suspended particle to come out also, if you do it cold the bleep settles on the bottom of sump and doesnt come out with the oil,
but i think what he is getting at is that the oil drains back from the galleries etc. Just check that the oil filter is tite as it is possible the oil is draining back from there. otherwise its not really a prob
FollowupID: 343023
Reply By: sean - Saturday, Nov 13, 2004 at 06:03
Toohey
The way I read the manaul you dont have enough oil. Check for correct level after a minute or so. In the morning it should read overfull but that is not when or how to check oil level. I think you are in danger of running the oil of the bottom of the stick on a long trip.
My 3 litre always showed overfull if checked cold.
Sean
AnswerID: 84183
Reply By: crowie - Saturday, Nov 13, 2004 at 11:54
Toohey
If I understand you right you are saying that when you check your oil after leaving the vehicle overnight the level is correct but when you check it half an hour after stopping it is only showing half full. I have a ZD30 and have never tested this. But I do know that the quantity of oil needed to change the level from the bottom to the top of the cut out section of the dip stick is only about 1 litre if that. You are better to be fractionally under full than overfull. I suggest that if its reading right when cold there is no problem.
By the way, for the ZD30 motor Factory Spec oil filter (cartridge) changes are at 10,000km and oil changes at 15000km NOT every 5000km. 50000km changes are for the 4.2 diesel. If you change the oil filter only at 10000km you will have to top up the oil. This is a hitech diesel and does not need 5000km oil and filter changes. Check it out with Nissan if you don't believe me. Newer LR Discovery's have 20000km changes I believe.
Personally for convenience I change both at 10000km irrispective of what type of driving I have been doing. Visually the oil, Shell Rimula X is still good for plenty more kms.
AnswerID: 84204
Reply By: hl - Sunday, Nov 14, 2004 at 08:31
Same on mine.. Is a bit confusing. I changed oil last week (just got the truck) and put about 8l in and ran engine, checked for leaks etc. When I checked level after I stopped engine, it was at low. So poured some more in. It has about 9l in now and reads overfull in the morning but just right after engine has run.
Horst
AnswerID: 84275
